AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Tanner Ridge Cinema Construction Thread
Tanner Ridge Cinema Construction Thread - Page 10
post #271 of 361
Due to the recent data loss, I thought I would repost the progress/pics.....
----->2008-08-04<-----
Well, it's taken months, but I've finally gotten around to dealing with the handrail for the stairs Not really a huge accomplishment, however, it's just one of those 99.9% done items that you never seem to get around to......
I was looking to have something black to fit in with the rest of the room, but didn't feel that painted wood handrail would suit it all too well. So, after some combing around the local hardware stores, I came up with an aluminum powder coat solution:
Deck railing
The trouble was, that the mounting brackets were terrible and I didn't trust them all to well. I found some 'regular ones' in brass that I figured I could adapt to my purposes
Not really a perfect fit, but with some quality time spent with a grinder, it would fit into the channel of the rail. So, with some grinding, some self-tapping sheet metal screws, and about 3 bazillion measurements, at last I have a rail that is to code:
I stuffed the insides with Roxul to reduce the 'clangy' resonance that it might introduce, and it seems to have given it a bit more 'heft' and feels a bit more solid to the hand.
It's amazing, but I guess I'm so used to a railing not being there, I keep forgetting to use it now
So I sat down, looked around, and thought to myself "I'm DONE!". Wept uncontrollably for a little, then thought - "wait.....I can't be done....noooooo........maybe I can upgrade or tweak something further?". I updated the front page pics to at least make myself feel a little better
More to come, no doubt
Cheers,
post #272 of 361
On a topic that's quasi-related to HT building, I wanted to post about a recent electrical experience I had this week and hopefully encourage forum members to consider their main breaker box as part of their home maintenance routine.
I had gone to my panel to look at some circuits to figure out where I wanted to install some more Insteon dimmers. When I opened the door, I could hear an ever-so-slight buzzing sound! Knowing that generally electricity is a quiet process, I began listening harder and it appeared to be coming from the 100 amp main. I popped off the lower panel portion for the branch circuits to have a looky, but did not see anything overtly wrong. I was hesitant to remove the upper portion that housed the main breaker - having 10 perfectly good reasons at the end of my wrists not to touch it! I called in an electrician friend immediately. What we found was a veritable ticking time bomb:
The wire from the meter base service to the main breaker had been degrading over a long period of time (40 years, actually....) - the insulation was beginning to disintegrate and creep up towards nearly contacting the inside of the panel - you can see the flat spot on the top loop of the wire.....
Needless to say, I had the service cut and the issue dealt with ASAP! But, thinking about it, how often when we are building that we never think of checking up on connections and the condition of the mains? Even in newer homes, if the mains were not torqued properly, this process of arcing or degeneration could occur and none of us would be the wiser until perhaps too late I spent a bit of time looking up info on breakers, boxes and such as I am going to upgrade to 200A service later this fall with a new panel (my panel isn't made anymore, and finding the new breaker was an almost futile event), and I stumbled across a number of articles and sites that deal with an issue over a certain brand of panels and associated failures:
http://www.inspect-ny.com/fpe/fpepanel.htm
I had no idea that this info was 'out there' and would certainly not be able to make an informed choice as a consumer as to what type of equipment would be installed in my home. Before I upgrade, I will now surely spend more time researching what equipment is available.
Bottom line, is that I'm putting this out there to encourage everyone here to think safety and check on your systems periodically!
Cheers,
post #273 of 361
WOW! Thanks so much for the informative post. You are one lucky guy to have caught it.
post #274 of 361
I like how the stairs go into the theater. Looks like cozy theater. I like it.
post #275 of 361
Tom,
Isn't it great working with a 40+ year old house! Good find on the wiring.
I've taken the plunge and started ripping apart my setup to use your rack solution (pics in my sig-thread). I have a couple questions. Any particular reason you used aluminum? I was thinking about using plexi-glass for mine. Do you have to manually turn on your Feedback Destroyer, leave it on all the time, or have some cool IR power solution? I would like to find SOMETHING to turn my amp and BFD on and off by remote. My searches have turned up very little.
post #276 of 361
Tom,
Thank you for the info on the Pegasus LED lights...I ordered 2 of them and they are awesome...just what I was looking for. Thanks again for the link
Allan
post #277 of 361
I also have an older home and knowing that I was going to be pushing some power in my home theater, when I built mine I upgraded to a 200 Amp service and took care of all these issues right from the get go. Count yourself lucky finding this time bomb.
post #278 of 361
Originally Posted by DevonS View Post
... I have a couple questions. Any particular reason you used aluminum? I was thinking about using plexi-glass for mine. Do you have to manually turn on your Feedback Destroyer, leave it on all the time, or have some cool IR power solution? I would like to find SOMETHING to turn my amp and BFD on and off by remote. My searches have turned up very little.
Hi DevonS,
I opted for the aluminum for a couple of reasons - I've worked with Lexan and other plastics before (projector mount, cabinet doors etc), and to have anything relatively sturdy/less flex, you would likely need 6mm or more....for me, that was too thick, and would not fit well with the trim around the edges of my rack. As well, I think it would be trickier to jigsaw plastics without the risk of chipping or cracking. The .063 aluminum (or a hair thicker) can be shaped and cut with regular woodworking tools and feels a lot more sturdy. Removing tool marks is a lot simpler as well using steel wool. The added plus is that it may help contribute to heat dissipation for the components!
I certainly think plexi might be worth for trying a panel or two, and see if it suits your application! Let us know if you do, and what the results are.
As for my BFD, I leave it on 24/7 as it draws very little, and retains my last selected filter setting (instead of reverting to '1'). I recall there was some discussion about triggering it by connecting it to a switched AVR outlet and such - but what I believe is that you have to power it on before the sub or else suffer the dreaded 130db 'WHOMP' when powering up. Someone might be able to elaborate further on that one? I'll have to check later...
I suppose what a person could do, is use something along the lines of two Insteon Outletlincs, and program them with an ISY (or software and an IRLinc) to take the IR signal and fire up a startup program - the BFD followed by the amp a few seconds later....
I hope that helps!
Cheers,
post #279 of 361
Originally Posted by bone_pa View Post
Tom,
Allan
Glad they fit the bill - I'm still tempted to put those everywhere in my house (but thats' waaaay too much retrofitting for me ). I love the LED look and the efficiency - I'm currently rebuilding my outside deck, and am exploring an inexpensive way to mount 50+ white LEDs under the black aluminum top railing to light up the glass....
boy, this stuff just never ends!
Cheers,
post #280 of 361
Tom:
Absolutely scary on the electrical panel problem, but thank goodness that you found it before it took the entire home up in flames.
That's really scary stuff...thank you so much for posting the info.
CJ
post #281 of 361
Tom,
Thanks for the info on the aluminum vs plexi. If I can find aluminum at one of our local metal surplus shops I'll likely go that route. Time and searching will tell I guess.
Also, good info on the start-up WHOMP. I wasn't aware of that little problem. I ordered an X10 IR mini controller and a Supersocket Receptacle so I'll play with that and see what happens. I just got my BFD so I don't even know what the damn thing does yet! A friend has one and all the mics and software for testing, so I should be OK there.
post #282 of 361
Originally Posted by YW84U View Post
Of note, is that the shelf bracket comes with holes to screw down the shelf - each shelf was screwed down to secure it. This is important, since some of the weight will be sitting over the area not supported by the bracket per se. This is okay, as the shelf brackets themselves have the two notched tangs on each side, preventing the shelf assembly from being able to tip forward.
Did you do anything else besides screwing the shelf into the bracket? I've cut all my shelves and some of the shelves themselves won't even sit on the bracket... they tip forward and hang down vertically. I think the problem is that I cut all the shelves to just fit the component in question, so I have some shelves that are only 7" deep and by the time I notch out the corners so it'll sit flush with the wall, there's only a couple inches actually sitting on the bracket. I had nightmares about all my stuff sliding out of the wall and ending up in a heap on my bar
I'm not worried about the bracket coming out, but they seem to tip a lot. Did your brackets have two tabs on each side (top and bottom) or did they look like this:
post #283 of 361
....I'm not worried about the bracket coming out, but they seem to tip a lot. Did your brackets have two tabs on each side (top and bottom).....
Hi Devon,
My brackets had tabs on both the upper and lower portions:
I think that the bottom tabs are integral in the prevention of any forward tipping. My brackets were from Rona - if You have one nearby, might be worthwhile to have a look at them and see if they'll fit in your rails.
For my components, some shelves were a bit deeper, so I have a mix of 9" and 12" brackets. I used 3/4 in MDF or plywood for the extra weight, and cut the shelves so that they extended to the bracket end as opposed to the depth of the component.
In your situation an idea to perhaps try is to secure the rear of the shelves to one another - you could 'connect' all of the shelves at the rear to increase the integrity - such as running a long threaded rod through the back corners with nuts/washers for spacings (such as what you would see in a DIY Flexy Rack), or connect them all with small wood strips. This would create a structural 'box' that would then just be suspended by the single tabs.
Let me know how you're making out - I'll try and think of some other options in the meantime
Cheers,
post #284 of 361
Thanks for you help, Tom.
Ha! Different stores. I'll have to check Rona. Got mine at HD. I have everything mounted in the rack right now and screwed the shelves to the brackets. I re-cut some of the shelves so nothing is tipping forward so far. I also thought about connecting the shelves at the back by screwing a strip of wood or metal or whatever. I also have some threaded rod sitting around that may fit the bill too. But I'll check Rona first.
Update: just got back from a Rona lunch-run and they have the dual tab thing-a-ma-whosits so I grabbed 'em.
post #285 of 361
Tom,
I have been very unproductive at work today going through your thread! It is truly amazing. I am going to building a rack into a closet this weekend. I was going to frame out a rack, but the way you built it seems great! So i have decided to steal/borrow/copy your plan.
Just a few questions. Where did you mount the rack rails? do those get in the way of the shelviing, or did you just cut around it?
post #286 of 361
There are no rack rails... the shelving is the rack.
post #287 of 361
Hi djalap,
as Devon stated, the two 'rails' are merely the component for the shelf brackets - there is nothing 'official' there in the way of rackmount gear
I jumped into a Rack thread some time ago, and covered off a lot of the process here as well:
http://www.avsforum.com/avs-vb/showt...5#post13046275
Plus, there is a ton of other really fantastic ideas and implementations by other forum members as well - its a great resource to see what has beendone and what might suit your installation!
Cheers,
post #288 of 361
Ah i got it! i see it more clearly now.
Stay close to your computer this weekend, i may be asking lots of questions!!
post #289 of 361
Tom,
I haven't written in a while, and I wanted to say thanks for responding to a question I had along time ago, back May.
Also, regarding your response talking about your HT experience:
The HT has alway been a big part of our family time together...and serves as a escape from the day-to-day trials and tribulations we all face...
...On another note, I'm actually almost 'sad' that the build is nearing the finish line....I'm sure many AVSers go through the same sort of 'empty nest' feelings when it starts to wind down.....
After reading this, and then after I finished wiping the tears from my eyes, I thought about the underlying reasons we do the things that we do. It's more and more clear to me that it's to connect with other people; especially with our family and friends. Despite the various interests in woodworking, equipment, DIY, movies, audio, and showing off one's accomplishments, often the real satisfaction comes in developing and enhancing relationships with your family and friends and other people.
Your account of your experience brought this home. Thanks for sharing it.
Peter
post #290 of 361
I have to admit that our home theater is pretty much family time also. My wife enjoys it when I'm doing this or that in the theater. As to having our theater nearing completion, I don't think that will ever happen, as I'm always thinking of new improvements. Right now I'm upgrading my electronics, next I can see a new CIH screen, a masking system, ... I guess the list will never end...
post #291 of 361
Could you possibly post some pictures from the back row with both 1.78 and 2.35 material? If someone was sitting in the front row during these pics, that would be great. I'm jumping back and forth between a 1.78 screen that sits lower than normal versus a 2.35 screen.
post #292 of 361
Hi DevonS,
Preliminary results, but it's progress. I started making a plate yesterday using the plexi. I have the .080" thick stuff. Used the scoring tool to cut the blank, then marked out the hole with a sharpie and cut using a jigsaw with a small scroll blade. It works great! Using a file to try to remove a mm here and there is a looooooong process. I cut well inside the lines to be sure it wasn't too big so now I have lots to remove. I think the angle grinder is going to be my friend. I'll throw pics up on my thread this weekend in case anyone is interested. I'll have to make a jig for the corner holes. Any tips?
Edit: Got a plate done. It's on my Cheap Seats Cinema thread.
post #293 of 361
Hi mn_hokie - I haven't forgotten your post; I've just been 'on the road' for a bit and actually took a break from theater building
I'm actually secretly scoping out the theater setups here to see what ideas I can steal......got a funny look / WAF factor when I suggested theater seats that shoot compressed air and water splashes!!!! I don't think it will fly......
I'll take a few shots for you when I'm back as so you can compare the different aspect ratios. I anguished over the same issue for a bit before deciding on the 16x9 route - for me it was the best of both worlds for the content we usually view.
Devon - Glad to see the ears come off - you're right, it does look way better flush!! The faceplates do take some time, but the end result is definitely worth it! I'll pop into your thread when I get back from dealing with all of the 'ears' down here
Cheers All,
Tom
post #294 of 361
The Purple Castle with Fireworks - Isn't that a strip club?
post #295 of 361
Well, after some lengthy time away from home, it's now time to go back to HT . Between holidays and work trips overseas, it seems nothing was able to be done around the house this past while!
Alas, not much new on the HT front, other than this new addition
Just need to figure out a place for it to live .
I have been considering taking the BR plunge and have been hanging out in the forums over there. After a lot of research, I think I've settled on waiting for Oppo to release the BDP-83 - I'm very interested in seeing what some of the early adopters have to say about this unit's performance. One the audio side, I've been looking at swapping out the main AVR for something a little newer - I've been looking at some of the Onkyo lineup, as well as Yamaha to replace my older Sony.
Upgrade-itis must be common in the winter months....
Cheers,
post #296 of 361
Whew! Just read through this as I followed you over hear from the DIY rack thread. Great job. Your room is the same size as mine is going to be so it's good to see.
post #297 of 361
Can you tell me how you cut the aluminum plates? I really like your component rack, and I am trying to build something similar. Thanks for any help that you can give me.
post #298 of 361
Hi claycurtis44,
For cutting the aluminum, I used a jigsaw with a fine blade to perform the rough cuts inside the lines, then switched to a flat file to bring the excess material up to the line I had traced. I used some clamps to help keep the material from sliding around the table, and also used some masking tape over the aluminum to keep the jigsaw feet from scratching the surface (although, you can steel wool out most of the minor marks you might make). It might take a few 'test fits' and more filing, depending on how many thousandths on an inch you want to be within the component
Here is a closer-up shot of it just prior to painting, and you can see the results of the filing and sanding:
There is some of the process earlier in the thread here:
http://www.avsforum.com/avs-vb/showp...&postcount=258
and in there there's a link to the entries in the DIY Rack thread as well.
The first one you do will seem a little daunting; that's okay - I found that each successive one got easier and easier as I went along and got better at the filing technique. It became a cinch to knock one out about every thirty minutes or so (depending on how fast your paint dries ). The nice thing is, that it is quite a bit of work, but the results can really add a good feeling of having done it yourself!
Good luck with your project
Cheers,
post #299 of 361
I totally agree, Tom. The first one took probably 4 hours to finish, second one was probably half of that... by the time I finished mine, it was two per hour.
By the way, I'm not regretting my choice of using plexi instead of aluminum like I thought I may. It does warp a bit when everything's been cooking for a few hours, but I have to look at it from a stupid angle to notice. Everyone is amazed at how clean they came out too... no sanding for me! And I was able to 'tune' the cutout using an angle grinder
post #300 of 361
I love you home theater.
I believe that i am going to follow you rack guide in my closet with some modifications. Where did you get the rack rails and brackets. Also, what type of screws did you use for the faceplates.
