Toshiba has been waging the nascent format war quite well IMO, but it sure looks like the deck remains stacked against them. The fact that no players other than Toshiba (and the rebadges) are out there does draw an eyebrow whenever I consider buying an HD-XA1 (which is more often than I'm comfortable with since I most impressed at viewing it in person at a Magnolia). The fact that the BD players keep getting delayed doesn't help them either and what should be a vastly superior library advantage has yet to appear. From my laymens pov, it sure looks like the BD launch was far premature.
If anything, this format war reminds me of the US Civil War. HD-DVD would be the Confederacy. Very effective out of the gate and inflicting rapid small victories, but they just looked doomed to failure once the mass of the BDA brings to bear so many more CE labels and exclusive studio support. At the very best, they look to be hoping for the fate of DVD+R/RW, which is how I was initially thinking this format war would resolve itself.
Anything could happen, of course, and without Microsoft, the war would have probably ended before it began. Toshiba needs to get at least another CE in the game before I could be really confident in them and the BDA needs to get their 1G players released, if not starting on a more affordable 2nd gen. The PS3 should fill some of that role, though, just as the 360 add-on some for the other side.
I would still hope for a DVD+/- R resolution, though. The two formats are so close with all the same codecs, etc, though some of the technical differences seem... expensive... going from HD-DVD to BD, they seem less onerous from BD to HD-DVD.
