Im getting more motivated to do this now so I'll start a thread here.
The basic premise is:
- 1 virtual display to show the source material (1920x1080)
- 2 monitor windows assigned a location inside the virtual display (left side / right side)
- fancy blending and overlapping algorithms.
And then later:
- easy to use setup program
- unlimited projectors 3x2, 3x3, 6x3 etc
- if you use an HDCP compliant Video Card, an internal NEC100A and WinDVD 8 you can blend HDDVD movies. (this is my ultimate goal
And then later:
