Hi Peter,
I guess we are going to have to disagree on this one.. I am by no means a compressionist, however I simply using some of the defaults in the encoder I have achieved great results... Some of the clips on our Demo discs I did the encoding for.. If you have a chance to see them please do...
At my office I have a Panasonic D5 deck and use a Key Digital HD-SDI to DVI box to view the content on one of our PRO-FHD1 which was ISF calibrated... I then captured the D5 using an AJA card and encoded it in MPEG2 using Sonics Cinevision encoder... We then compared it with the original...
When encoding VBR (goal 20, low 15m and high 40), the difference between the D5 and the BD file was not visible.. When encoding at a CBR 35 I still could not see a difference either (Maybe a little but it could have been my mind playing tricks on me).... If I had a newer VC1 encoder I will use it as well......MPEG2 encodes in almost real time on the PC I use...
Chris
QUOTE=PeterS]Chris,
Having done a lot of MPEG-2 encoding in my day, I have to take objection to your comments.
First, MPEG-2, even on standard DVD has never looked "good". Even in the best examples there are artifacts and problems which we look to remove with processing, etc. When it comes to HD, we are even more picky about quality issues. MPEG-2 does not cut it at all, especially when the goal is to get as transparent to the source as possible with as little bandwidth required as possible.
Second, as for BD vs. HD-DVD - personally, I do not really care. However, there are some things which concern me. Given the "automatic/real-time" nature of MPEG-2 encoding tools, I think we are getting a lot of very sloppy encodes. Additionally, BD has several layers of compatibility - I am very sure that content will march to the lowest common denominator here and that extra support features (dual video decoders, interactivity, network support) will find little support as the march to get the players cheaper drives sales targets.
Lastly, while I respect Pioneer's work, and still have one of your Elite Laserdisc players in my rack, I can not help but wonder what the response at Pioneer is to having the PS3 out in the market at 1/3 of your MSRP, containing a fair amount more features and upgradability out of the box than your own Elite player? Personally, I was planning to get the Pioneer player, until the delays, (the reasons for the delays), lack of 1080p24sf support, and other sundry missing capabilities (playing an audio CD - for example).
At this point, I am going to support HD-DVD with the HD-A2 and the BD camp with the PS3. If in the future, Sony gets off its ridiculous MPEG-2 bandwagon, and the studio support for VC-1 increases on BD, then I will once again consider one of your stand-alone players.
However, at the moment, the potential increase in capacity of BD-50 is totally eaten away by the "bloat" of MPEG-2. With HD-DVD-45 coming around the corner, if it is even needed using VC-1, I see no practical purpose in gambling the $1,000 differential that it would cost for a stand-alone at this time.
Once again, however, I am VERY HAPPY to be proven wrong :) ![/quote]
