We had a little shootout In Olympia WA last night featuring the mighty G70 vs, the fresh off the truck Marantz VP-11S1.
Sources were identicle overlayed clips from HD-DVD.
Results.
Sharpness 11S1 easily
Shadow detail 11S1 easily
3d effect/dynamic range in darker scenes G70
3d effect/dynamic range in daylight scenes 11S1
3d effect/overall probably the G70
Color accuracy 11S1 easily
field and color uniformity 11s1 easily
quietness G70 wins
ease of use 11S1 hands down
These were two great projectors! The G70 was well kept and tweeked and I was amazed that this ten year old technology still holds its own against the latest and greatest.
Its clear that most consumers would choose the Marantz for ease of use and solid clean picture. In a blind test switching back and forth between scenes 10 out of 10 would probably also choose the Marantz. It's Sharpness, Color accuracy and uniformity is simply in a different league. BUT we would all be happy with the G70 without a comparison as it's simply a fantastic image too.
Value? you can pick up a beautiful G70 for under $5k but the Marantz costs $20k MSRP.
Now for the downsides. I kinda expected the Marantz to be better. This is a tough call as the owner probably got my expectations a bit too high. This new model was clearly better than their previous 720p units the S3/S4. Yes you could still see rainbows. And if this bothers you dont kid yourself they are still there. faster processing and 1080p resolution hasn't changed this at all. It still uses the best 1 chip DLP has to offer, a 7 segment 6x color wheel. Speaking of which is definately the largest downside of this projector. Its loud. This projector is much louder than others in the industry; Pearl at 22 decibles and the Mitsubishi at 18. Not just the fan was too loud but the color wheel simply has a high pitch squeel that would require a hush box if you're trying to build a top notch theater. This simply cant be overlooked.
They both threw beautiful images and I just wish I had the $5k Sony Pearl there to comare. I think the owners of both the other projectors would have been shocked!
Results.
quietness G70 wins
2 things that come to mind
