Originally Posted by Bambus
Hey,
I just got the DVD. Thanx to all that made it possible. Its a great test tool for any HT, big or small.
One question to all though. In 5.1 tests, when you test the levels and you have a choice of each chanel, when i go to LFE, i got no sound. The only way i get the sub to output is when I select MAINS or LEFT or RIGHT, only then the sub is mixed in that test. Any ideas on how i can isolate the sub to be on its own ( or is it possible?)
Im running the tests using Pioneer VSX1015 - sub out, Y spiltter to a powered sub L and R inputs.
Thnx
Hey,
Thnx
you sure your reciver is working at 5.1 during those test? it sounds like its running in stereo or dsp mode and simply mixing the lfe to the mains and the sub at the same time.
Then, using a radio shack SPL meter, I confirmed that my -3dB response was 19Hz; previous measurements with RoomEQ and the meter indicated this as well.
, I want to add that I am trying to get the DVD levels checked by an outside source. Several avenues have went sour, but I have hopes another will pan out.
