AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › OK! Your LCD! You Tell Me! Got a new one? post it here
OK! Your LCD! You Tell Me! Got a new one? post it here - Page 6
post #151 of 1489
1. The "Model" you have.
Sharp 32D42U
2. What convinced you to purchase this particular model.
Mostly price and relative picture quality on display models.
3. What you like best about your LCD.
Picture Quality is great on HD and SD.
4. What you don't like about your LCD.
Nothing so far. wish it had cablecard, but don't really need it since i use QAM on analog cable.
5. What "Feature(s)" you wish your LCD had.
Cablecard.
6. What advice or suggestion would you make to the "Manufacturer" about your LCD.
Keep driving the price down.
7. What was your biggest "Surprise" after you received your LCD.
Quality of SD picture directly form analog cable. Better than my old CRT SD TV.
8. What "Problems or Issues" have you had with your LCD.
None so far.
9. Do you really think that todays "Prices" are worth it.
This cost less than the inflation adjusted price I paid for my 32 inch CRT back in 1995.
10. Any additional information that you want to add is encouraged.
Really should explain QAM to the beginners, like me, in this forum. What a big win!! I get HD on all networks plus several PBS channels, plus a bunch of other misc channels from my analog cable with no cable box.
Second, quit discouraging folks with stories of imperfect displays and unwatchable SD. SD quality is very good on my cable/TV combo. If you believe everything written in this forum you would just stick with your old CRT SD and wait for another 10 years to buy that new set to get that gigahertz refresh rate and billion to one contrast. This is like buying audio speakers with a frequency range of 0-200Mhz. Way beyond human perception, but beginners become convinced they can't watch/listen without it.
post #152 of 1489
1. The "Model" you have. KDL46"XBR3
2. What convinced you to purchase this particular model.THE BEST LCD ON THE MARKET
3. What you like best about your LCD. PICTURE IS THE BEST!
4. What you don't like about your LCD.N/A
5. What "Feature(s)" you wish your LCD had. MORE HDMI
6. What advice or suggestion would you make to the "Manufacturer" about your LCD.PLEASE FIX THE CLOUDS
7. What was your biggest "Surprise" after you received your LCD.THAT IT HAD NO CLOUDS
8. What "Problems or Issues" have you had with your LCD.NONE SO FAR.
9. Do you really think that todays "Prices" are worth it.YES AND NO
post #153 of 1489
Toshiba 42LX196.
Selling HDTV's as a part-time job, I got a good look at LG, Toshiba, JVC, Sharp, and Phillips. The Toshiba looked the best, and wife agreed.
The price I paid as an employee only working 4 hours a week!
I cannot think of a single thing.
I would value a third or fourth component and HDMI input I suppose. A firewire output for a Simbio would be nice. I'd also like an SD card reader. See #9 below regarding these features.
The motorized stand that Hitachi's were using would be a nice touch.
My wife couldn't tell the difference between analog TWC feed and OTA 1080i. I do not understand this mentality.
The CC was turning itself on randomly for a while, but it may have just been operator error. Time will tell. My wife is not hip on having to switch inputs and handle this many remotes. This has prompted the purchase of the Harmony 880 due-in tomorrow.
Selling these things, I've seen the prices (cost and retail list) and can tell you that this is the best time to buy right now. In another year, the prices will undoubtedly be less expensive, but at a cost. Jack packs are dimishinging, swivel stands and all bells and whistles are slowly taking a backseat to pricing wars with WalMart branded T.V.'s coming out of China.
Toshiba's scaler does a wonderful job of upconverting a 480p DVD to 1080p. I cannot see any pixels.
post #154 of 1489
Westinghouse LTV-32w6
Price / value and comparing several other higher priced displays.
Clear, sharp, bright picture. No problems right out of the box.
Remote is weak and very directional.
PIP & DVI
6. What advice or suggestion would you make to the "Manufacturer" about your LCD. A
Add more aspect ratio settings. The two available don't do this model justice.
SD channels look good. The overall picture quality is much better than expected. Sound is also good.
None. No quality issues after two weeks.
No...
I think the firmware ver. 5.00.68 resolved a lot of problems. Out of the box this set had no dead pixels, no noticeable ghosting, no backlight problems or banding issues. If it lasts several years it will be an excellant value.
post #155 of 1489
Magnavox 32MF231D
I was looking for a "entry level" HDTV that was relatively inexpensive, was at leat 32" and had a good picture.
HDMI allows me to connect my upscaling DVD player .
I would prefer a black cabinet rather than the silver, but this one is OK.
Multiple HDMI's instead of multiple component and composite inputs. Also a VGA connector would be nice.
Make selection of inputs using buttons on remote, instead of menu pull downs or advancing channels.
The ATSC tuner was able to bring in 10 or so Digital channels over an old UHF antenna I haven't used in years. I am about 50 miles from the transmitters so this was a nice suprise! I am waiting to change my Satellite programming to HD until the DSS companies have more channels available and have worked through all the HD-DVR issues.
When changing channels very quickly using the remote, the TV has locked up on two ocassions. I had to remove the AC cord to reset. I am going to check the firmware and upgrade to see if this corrects this problem.
Still a little high, but I am pleased with the sale priced, open box, 24 months same as cash financing I received.
I like the SPDIF audio out put which allows me to run the TV tuner audio through my Bose receiver.
post #156 of 1489
Just got a new LCD Flat Panel? Post it here ONLY. Please do not post projection models.
Tell me the following:
Westinghouse LVM-37W1
1080p and price not to mention good PQ (in my opinion)
good PQ, lots of inputs!
bad remote, blue power light at bottom right corner
HDMI
better remote!!!
how good the picture gets with proper tweaking. also, the importance of mulitple inputs!
none yet
am not entirely sure
i am really happy with what i got for the price. (1099 canadian dollars!)
post #157 of 1489
LG 42LB1DR
Great picture quality with ALL of the features I wanted. I originally got an LG 37LC2D, but was not satisfied. I really like the on-screen guide feature.
The TV Guide on-screen and built-in DVR are absolutely awesome. I no longer use my Panasonic DVD recorder, which was always a bit klunky anyway. Picture quality is great (HD and SD), and menu navigation is easy.
Having to change screen ratio settings depending on the show. Not always consistent. Remote-control design not the greatest..
A bigger hard drive
Selling a set with a built-in dvr and ONE tuner is a mistake. You really need two tuners, so you can watch one show while recording another. You should also include the biggest hard drive possible.
That the built-in TV guide feature is much more useful than my older "Guide+" on my RCA analog set, and despite the pickiness of several people in these forums, my lcd set's picture quality and brightness and color are amazing, period.
Recordings seem to cut off a minute or two early. I am still playing. This is adjustable.
Not really, but they finally became "affordable" (sort of) for me. Got my set for about 50% of its original price.
One thing I get annoyed at is how many people do not realize that you can get *really good* television, and tons of HD content, over the airwaves. As in, broadcast television. No, you won't get ESPN, but many cities offer far more in digital tv signals than the analog counterparts. Many prime-time shows are in full HD now. *NO CABLE OR DISH REQUIRED*. Just a regular old antenna. Voila. In my city (Milwaukee, the analog stations are 4,6,10,12,18,24,36, and 58. That's 8 stations. In digital? We get: 4-1, 4-2, 6-1, 10-1, 10-2, 10-3, 10-4, 10-5, 10-6, 10-7, 12-1, 18-1, 24-1, 24-2, 55-1, 55-2, 58-1, 58-2. That's 18 stations compared to 8. Two of those are desdicated 24x7 weather. Just like cable... almost If you are considering getting a HDTV, check out "titantv.com", and see what digital content you have in your neighborhood *before* being sold a crappy dishtv deal by the BB or CC dude.
A lot of this is consumer ignorance, but a huge part of this is ALSO due to salesdudes basically "implying" that in order to get HD content, you need a cable or dish setup. I wonder how many people have thrown tons of money away because of this false impression............
post #158 of 1489
Runco CX-46HD
The hope that a premium brand would be more reliable and
I could avoid the sony, samsung, sharp kind of issues. (we'll see...)
It tunes "everything" and PIP HD locals. Blacks are excellent,
and no clouding or anything reported here on AVS. (checked with
9 year old and 6 year old eyes)
There's a problem here on the first day with either scratched DVD's
out of the oppo 981, or the 100 ft cat 5 hdmi. The TV goes black
screen during movies and I have to switch inputs or turn it off and
on to clear the problem. Need to figure out if it's the TV, the cat 5,
or the oppo. Simple debug in the next few days will sort this out.
(same issues feeding oppo output to the older Sony 32" 720p)
so far, so good.
More details or options to integrate OTA, cable, and satellite. (I'm
trying to compare inputs...)
How nice it looked in the livingroom, and how simple it is to
look at various inputs and tune channels OTA.
See above, but I don't think it's the LCD yet.
yes. There is a wide range of prices, features, and sizes for
people to choose. Yes, I wish mine cost less, and hope it's
worth the extra.
I plan to put it through it's paces this weekend with the superbowl
and more types of inputs. I'll figure out the black screen thing with
DVD's where scratched ones are far worse. I'll also use a VCR
for RF demod and play around with OTA and cable HD over the
next week or so.
post #159 of 1489
Panasonic TC-32LX60
It looked better picture quality wise (albeit on the Circuit City floor, so who knows how bad some of the settings were) than the other models I was looking at and I also trusted the Panasonic brand more than, say, LG or Olevia.
Picture quality and the speakers (not too bad for built-ins)
Inputs! 1 HDMI and 1 Component only is pretty limiting (Why would anyone need 3 composite inputs and 2 S-Video inputs on an HDTV?)
A VGA input
Inputs, inputs, inputs. Not a fan of the silver/black (should have splurged for the all-black 600) or name (Viera) either.
That it only had 1 component input (this is clearly a bigger issue with me than it should be, heh)
None so far
Sure. It's just an entirely different experience when watching a movie or TV in HD.
post #160 of 1489
Samsung LN-S4695D
I needed a panel format due to restrictions of placement in my new living room, so i was looking at either plasma or lcd. i use an HTPC, and have lots of windows in the room, so LCD was the choice. The Samsung had the same panel as the Sony (which is largely considered the best LCD), and was substantiall cheaper, and had a way better looking bezel (to me).
Picture Quality, "look" on wall, depth of blacks for an LCD.
the remote is utter crap. It feels cheap, and has a very narrow I/R "spray"
Analog sound input to use the speaker as a center channel.
allow PIP with 2 digital sources.
N/A
slight variation in backlighting on a blank input screen (all black) I can see some lighter cloudy shapes. The set makes popping sounds when warming up.
Absolutely
post #161 of 1489
Sony 32' XBR2 (our 2nd HDTV)
XBR series (returned a V2500 for it )
Picture Quality,
cheap stand, only 1 HDMI
More HDMI
More inputs
none
awaiting our 2nd set...2 pixels always on...1 bad pixel...cloudiness on a blank screen a little back bleed
today they are tommorrow they wont be
for me best time to buy a set, I couldnt afford last year
post #162 of 1489
It's hard to go through all of your questions without going back and forth between screens because I'm just dumb. But I love the Vizio L42. I looked at it on the shelf at Sam's next to several other 42" LCD's such as Samsung and Westinghouse and Phillips. The floor guy found the remote and let me play with the Vizio. I was able to find the custom picture settings and made the TV look very similar to the other units next to it. The whites are much better than some and the black is acceptable to me. The sound fills the whole room which is 26' x 42' although it does need a subwoofer. I switch from the normal to cool temperature mode when watching an animated DVD because of the extra color saturation in the animation. The screen is so bright even in a room full of Andersen windows that I reduced it twice!
OK, I have two questions. Does anyone know how to mitigate the loud sound at power up? The sound seems to come out full blast for about half a second as the TV is warming up.
Has anyone noticed a definate and striking reduction in picture clarity and color quality when looking at the S input versus the composite input? I have a TIVO going into the composite input - could it just be the TIVO?
Thanks everybody!
post #163 of 1489
Bravia KDL-46V25L1
Best HD picture; good price at Costco.
HD picture quality - the colors, sharpness and clarity.
So far nothing.
DVI input.
None.
How easy it was to set up and start watching.
None.
No, because I know prices will fall and the technology will get better, but that's true for most electronics.
No "clouds" or any other noticable defect.
post #164 of 1489
Sharp LC-32D40U - 1st HDTV
Price - great deal at Office Depot
HD picture is incredible!!!! Wish there was more HD programing
Sound quality of built in speakers is better than an stereo TV I've owned
QAM tuner - FREE HDTV!!
Need more "favorite channels" for QAM use (only 4 on remote)
PIP and alarm (used to wake up to old RCA coming on)
Better remote - smaller, better layout, better favorite channel options
HD PQ looks so much better than in stores.. WOW!
This model does have a "red push" problem. I only notice it when watching Tivo though. Simple adjustment fixes problem
Mine was! Would buy another in a heartbeat if I needed it
Don't order anything from Office Depot. Bought on a Sunday, said it would arrive Wednesday. Wednesday was told it would arrive Friday. Friday web trace showed it had been delivered. It hadn't (tracking number OD provided was bad). Was told it would be Tuesday. Arrived in good condition on Monday but the frustration and POOR customer service throughout the week kind of took the wind out of my sails. Still worth it, especially of I get the $200 rebate I just put in the mail.
post #165 of 1489
DOMA 47" LCD4721HD 1080P
One of my old flatmates started this brand in Hong Kong.
The design is ten times better than Sony/LG and on par with B & O. LG panel -managed to get it 60% off the retail price!
A little tacky behind the design -i.e. the AV inputs etc on the back. Could do with more QC
2 HDMI / USB ports instead of one
Better QC
The technician bleeding all over my floor after a screwdriver slipped and went into his arm and then taking him to the hospital.
White patch in bottom left corner -getting inspected tomorrow though.
No. But they will be in about a year's time hopefully -with manufacturing costs lowering.
10. Any additional information that you want to add is encouraged.[/quote]
If you can find DOMA products take a look -the design is really nice and they use Samsung / LG panels depending on current batch quality.
post #166 of 1489
Bravia KDL-46V25L1
Beautiful non blurry picture, got it for an unbelievable price
the 1080P using a PC with DVI to HDMI cable. HD picture is awesome - I only have 5 HD channels though on my Time Warner.
Nothing yet, other than the channel takes a second or so to load.
DVI input. Split screen like the sony projectors. Dual antenna inputs
use backlight with white LEDs!!
Good - connected a PC to it and was amazed
Bad - It required 40 minutes to dig all the digital channels
Nothing yet!!!
The price I got this for is good - could be cheaper as the technology matures.
I did not notice any weird artifacts/pixellation. Watching the Super Bowl was awesome you could see individual grass blades.
post #167 of 1489
Sony KLV40U100M 40" Bravia
The Price ($1299) and picture quality
The picture and the PC input
Nothing to speak of
I wish it had another HD input. It only has one HDMI and one component
Just to add either another HDMI or component input
How much better the picture looked compared to the RP tv I had before
Nothing yet (knock on wood)
Compared to what they were a couple of years ago, yes
I'm really impressed with how good this TV looks with both my Oppo 971H and my D* H20. The colors really pop off the screen and SD content actually looks good.
post #168 of 1489
-- Sharp 37" Aquos D90 --
37" size, full 1080p resolution, great reviews, nothing but positive comments on forums like this one.
The remote control is perfection. Best I've ever owned. I love the easy to program and use favorite channels especially. You can program 16 of them and they're surprisingly easy to use to go to my favorite channels. Picture quality is stunning. Eveything I've tried to set up was easy: Easy to search channels, select the ones to skip for example. Trivially easy to set up: I was watching HD inside half an hour. I don't have cable so the built in tuner was very convenient: just plug in the antenna and you're set. No dead pixels. Freeze frame: never had that in a TV before. I love it. And the frozen pictures are surprisingly sharp and good. Color, contrast, it's all unbelievably good. I LOVE THIS SET!
On some standard resolution 480i digital OTA channels there's an odd line of static at the very upper edge of the screen. Not on all, but on some. Don't know if it's the TV, the antenna, the station, etc. There's an odd clicking/rattling sound sometimes during parts of HD surround sound broadcasts, again not that often but enough to convince me it's either the TV's problem or there's something sitting on a nearby surface that resonates and rattles at just the right frequency. SD content could be a little better I think. Hard to say though. Slow switching channels. Sometimes you can switch right away but often there is an annoying delay between the time you press the button until the channel changes. Sometimes I think it didn't "register" so I press again only to be sent too far.
A smarter zoom? Widescreen SD broadcasts and DVDs have black bars on both the sides and the top and bottom. Isn't there a way for the TV to make one or the other set go away without stretching/distorting the image? A way to output analog signals to my analog VHS, DVR, etc.? Wishful thinking I suppose ... I'd really like there to be some kind of immdediate feedback when you switch channels. Even if it takes awhile for the set to actually "acquire" the new channel or whatever it is that it does, it would be great if there was at least something on the screen that told you instantly that it knows you switched the channel.
Nothing comes to mind at the moment
The size. 37" looks a lot bigger in my bedroom than it does in the store. Still I'm very happy with the size and I'm glad I didn't get anything smaller (or larger). It was heavier than I expected. I'm surprised at the complete lack of glare. I often watch with a light right behind me and was annoyed by glare on my old CRT television. It took me awhile to even be aware that this TV had no glare at all, but when I finally realized it I was surprised and delighted.
Nothing, other than my list of things I don't like above.
Yes. Absolutely.
This is the first HD set I've owned and I'm astonished at the quality. Nothing in the stores looked as good as this. But not having owned one before or even having had a chance to watch them outside of stores I may have nothing to compare it to. I'm convinced this was the absolute perfect time for me to make the HD leap, any sooner and there wouldn't be as much HD content out there to make it worth the higher price. Plus this was one of the first 37" sets that could do full 1080p. And YES, I notice the difference even at 37" (I set about 8 feet away from the set). I can tell instantly the difference between a 1080i broadcast and 720p one. Especially for video, the difference is dramatic. Not so noticeable for film though.
post #169 of 1489
SHARP LC-46D62U
WARRANTY REPLACEMENT BY SHARP FOR 10 MONTH OLD SHARP LC-37D4U
1080P RESOLUTION, BIGGER SCREEN AND BETTER COLOR
MINOR FAINT HORIZONTAL BANDING
ONE EACH EXTRA HDMI AND DVI FOR COMPUTER
FACTORY CALIBRATE THESE SETS (RED PUSH)
PRESCREEN FOR BANDING (QC)
HOW GOOD THE 1080P PICTURE QUALITY IS WHEN PROPERLY SET UP.
BANDING
AT THE CURRENT PRICE THIS SET IS A BARGAIN
NEEDS A GOOD SIGNAL SOURCE (1080I/P)
LOOKS GREAT OVER THE AIR(1080I)
GOOD AUDIO FROM INTERNAL SPEAKERS
SURFS FAST WITH EXTERNAL TUNER (MOTOROLA 6416 TW CABLE BOX)
BEAUTIFUL SET
post #170 of 1489
Sharp 46D62U
Price, quality and I like the piano finish - same as f1
PQ
1 stuck pixel in the centre of the screen
PIP
Fix the banding for other users - it's killing them
Handles component video from SD satellite pretty well
Stuck pixel.
Mine was.
post #171 of 1489
Samsung LNS4096D
I like the features and the prices was good.
The brightness of the picture.
I've only had it for 5 days, haven't found anything bad yet.
I don't know what I am missing yet.
None.
Just plug the cable in and I get HDTV.
None.
They are ok.
I like the picture.
post #172 of 1489
- Mitsubishi LT-46231 (Diamond Series 46" 1080P LCD TV)
- Positive reviews here. Solid deal. Not overly popularized/unknown by most. The only 1080P LCD which didn't seem to have problems unlike those LCD's from Sharp (banding), Sony and Samsung (clouding and motion blurring), and Toshiba (ghosting).
- So far I'm relatively impressed with the SD feed. The HD feeds take my breath away. Perfect Color and Perfect Tint adjustment allow user adjustability of six separate spectrum colors to get the perfect color output. Much more than just your basic tint and color adjustment bar you get on other TVs. Color output is incredible when calibrated.
- Nothing yet.
- A third HDMI input and 1080P over component (up to 1080i only).
- Keep on putting out an incredible flaw-free LCD!
- How easy it was to set up and the color output when up and running.
- None so far.
9. Do you really think that today's "Prices" are worth it.
- Yes, as they have come down substantially from a year ago at this time.
- Consider this "undiscovered" Diamond Series LCD if you're shopping for a 46" 1080P LCD. You might just find that this is the perfect LCD TV. I know, I've looked at the others (Sony, Sharp, Samsung, Toshiba) and this is second to none!
post #173 of 1489
1. Westinghouse 47" 1080p LCD (LVM-47w1)
2. Price
3. Looks great with the my media PC as well as HDTV
4. Everything about the remote sucks
5. Wish it had better adjustments and more pip options
6. Make it more TV friendly
9. Can not go wrong for $1,800
10.
post #174 of 1489
1. Poloroid FLM 3732, puchased 1 week ago from CC with the 3 year service contract.
2. Price, user-reviews, and availability.
3. Picture.
4. a) Audio: 3 of the 4 internal speakers failed after a few days. I'm using 4 external computer speakers including a woofer (all from a Logitech X-530 via RS adapters). b) Remote: only the volume control works. Won't even shut off the set.
5. blacker blacks. ..and reliability.
post #175 of 1489
Samsung LN-S4051D 40" LCD
Won it as Grand Prize in the "Doritos Win A HDTV" contest. They gave away 300.
DNIe... and that it was FREE!
No cable card slot.
See #4
None.
How crappy non-HD digital cable looks, and how beautiful OTA HD looks.
None.
Nope.
Gotta make a decision here shortly about maybe ditching Cox cable for DISH or DirecTV for HD provider. Off to look around!
post #176 of 1489
very helpful
post #177 of 1489
1. The "Model" you have: Sony KDL--32S2400
2. What convinced you to purchase this particular model: IMO, compared to the Samsungs, it has a superior PQ--also need a 32" to fit in the wife's cabinent
3. What you like best about your LCD: The HD quality--simply stunning!
4. What you don't like about your LCD: needs another HDMI port
5. What "Feature(s)" you wish your LCD had: 1080p would be cool, but for a 32" I guess it really doesn't matter....
6. What advice or suggestion would you make to the "Manufacturer" about your LCD: another HDMI
7. What was your biggest "Surprise" after you received your LCD: how crazy good my Xbox 360 looks on it
8. What "Problems or Issues" have you had with your LCD: some "bleeding in the corners
9. Do you really think that todays "Prices" are worth it: it's all relative I suppose
10. Any additional information that you want to add is encouraged: I would not hesitate to but this tv again!
post #178 of 1489
1. The "Model" you have: Sylvania 6637LCT
2. What convinced you to purchase this particular model: The wife.... seriously. She pointed it out and suggested it over the 32" I was looking at.
3. What you like best about your LCD: Picture, price.
4. What you don't like about your LCD: Nothing yet.
5. What "Feature(s)" you wish your LCD had: VGA input. I would also like to see the ability to add channels manually in ATSC mode.
6. What advice or suggestion would you make to the "Manufacturer" about your LCD: Mention the QAM tuner in the literature.
7. What was your biggest "Surprise" after you received your LCD: Once again, the QAM tuner.
8. What "Problems or Issues" have you had with your LCD: None yet, other than the QAM not being able to pull one channel that a $350 set I have upstairs on a lower quality connection can get.
9. Do you really think that todays "Prices" are worth it: Can be if you know what to look for. Much better than just a few years ago.
10. Overall, this set gives quite a bit of bang for the buck.
post #179 of 1489
Samsung LE27S71 HDTV (europe)
1. Price 800 euros. Design and the image quality, but the price was the best reason, as when compared to other more expensive models, it was the best option
The image quality and its Design
the few clouds when on black screen
an added hdmi port and hd receiver imput
Resolve the Cloud issue on these current models!!
well i did alot of research, so i nearly knew everything about my tv, but i am still impressed with the image quality when i watch a nice movie.
as already stated only some few clouds.
well actually yes, thats why i baught mine.
nope
post #180 of 1489
Samsung LNS4095D
Amazing picture, good feature set, beautiful design.
Image quality and design. Awesome for Xbox 360!
Black levels could be better, but that is to be expected with any LCD.
Another HDMI input, ability to adjust all VGA settings.
Allow users to adjust all VGA settings...not just brightness, contrast, and a couple others.
How truly amazing the Xbox 360 looks on it.
I don't get to watch it enough!
Not quite...but I did manage to get mine for $1000 off retail due to a sales error!
This is a great LCD. I consider myself a novice when it comes to Home Theatre...however, I am 100% satisfied with this purchase.
