Thanks to MS for the latest Xbox 360 1080p HD-DVD (etc.) update. Hopefully it's kosher to start a separate bug and feature request thread for the next update here...
I'll start:
I appreciate having the new Aspect Ratio button, but unfortunately it's missing one setting for those of us with older TVs. Some of these older TVs lock into widescreen mode when presented with progressive scan or HD content. This is a major issue with 4:3 material. To better explain:
My 16:9 TV is hooked up to the Xbox 360 via component 1080i.
Original 4:3 480p image:
What that image from the Xbox 360 is supposed to look like on a (recent) 16:9 TV in Default Aspect Ratio mode:
This is the Xbox 360's Default mode on my (older) TV. The image is stretched horizontally:
Horizontal Stretched mode looks exactly the same on my TV. This is what it should look like on a newer TV as well:
Letterbox Zoom mode on my TV corrects the aspect ratio, but cuts off the top and bottom:
What would be nice for the next update would be to have the Aspect Ratio button have an additional option where the Xbox 360 would add (107 pixels of) black space to each side, before output. This is how my HD cable box deals with 4:3 HD output. Even on my TV, such a hypothetical "Fixed 4:3" mode would display correctly:
I can't test the HD DVD drive yet (since it's still a couple of weeks before its release), but I suspect the same issues exist using the new Aspect Ratio button with HD DVD 4:3 material. (Or maybe not. See my next post below.)
[EDIT]
This is apparently NOT an issue with 4:3 material on HD DVD (either 4:3 480i/p or 4:3 1080p). It's only an issue with 4:3 DVD playback. See post #16
[/EDIT].
eg. Casablanca:
Original 4:3 Casablanca aspect ratio:
I suspect it will look like this on my TV (but maybe not - see my next post below):
A "Fixed 4:3" mode for the next update would be most welcome.
Now I'm off to test 720p and 1080p WMV video playback off DVD-R...
I'll start:
[EDIT]
[/EDIT].
eg. Casablanca:
720p video works fine though.
