AVS › AVS Forum › Home Entertainment & Theater Builder › Outdoor Theaters › Recommendations for cheap rear-projection screen material
post #1 of 4
First off, I would like to thank everyone in this forum for sharing their knowledge and experiences.
For Halloween I decided to do a rear projection movie from my garage. Based on some prior posts I purchased two frosted shower curtains from Walmart. Total cost - $6. Showed Corpse Bride and the neighbors loved it and are now asking for a monthly movie night. So I'd like to get a slightly better screen!!
Can anyone recommend relatively cheap material which would make a good rear-projection screen. Thanks.
post #2 of 4
Try the 9.99 frosted shower curtain from Walmart. It is a heavier guage vinyl. I bought both but only used the 2.99 one for Halloween. Haven't tried the heavier one yet.
Good luck!
Tom
post #3 of 4
The Mainstays $2.98 frosted clear curtain is from Walmart. No hotspotting issues. Works GREAT!! Buy two curtains and use clear 2" tape and have a screen 70" x 140". I also bought the heavier shower curtain Tom talked about and the difference between the two is nil. Besides, for the price of one you can have 3 curtains!!
As to better quality, the only way I could see improvement is to heat out the wrinkles and folds. That or get true rp material which costs wayyy more than shower curtain.
http://www.imagestation.com/picture/...8/ec3e6adf.jpg
Note Marge's hair
Victor
post #4 of 4
FYI - This summer I cut open a couple of white plastic kitchen garbage bags, laid them flat and taped them together, and hung them from a wooden dowel supported by a couple of 2x2 screwed into the railing of my deck. Aside from the seems, which were not all that noticable, it made an outstanding outdoor rear-projection screen. MUCH better than the poly/cotton bedsheet I'd tried earlier.
  Back to Forum: Outdoor Theaters
This thread is locked
