Originally Posted by JVoth
Normally I get on here and tell people that no receiver will truly allow your M&K's to reach their true potential. For a 750 sq ft. apartment, I would say you should stick with what you have. I don't know what price range you are looking at either. But if you feel you must upgrade, then I will suggest the Marantz SR5005. You can get a b-stock unit at Accessories4less.com for around $500 or so. I am suggesting that particular model not because of a power upgrade, but because it has preouts. With preouts you can then buy yourself a separate amplifier later down the road. I will stick with the fact that these speakers were not meant to be powered by all-in-one receivers. They are power hungry and not exactly efficient. So that being said, I don't think in your situation with a smaller listening area, that a new receiver is going to give you better results as far as sound quality goes. An amplifier will, however. If you are worried about the 4 ohm rating, I ran my 750 system with a Yamaha receiver for several years before I discovered what separates can do, and I never had any issues at all.
Thanks. I am going to stick with the receiver and upgrade down the road when I need to.
