How do you run them now? The SS-150 is a di-pole, direct and tri-pole. General rule I go by is how close do folks sit to the side speakers. If they are not too close, direct is fine, otherwise di-pole can help. Also, do you play multi-channel music? Directs tend to be preferred for that. In the end, you gave the best answer. Test what you like. Nothing any of us can say, can beat that.
Goo B Gone. Works like a charm, but keep if off your teeters and woofers. It tends to undo some glues.That may be best. Save the foam in case you ever need to replace a tweeter.
