Originally Posted by
A/Vspec
Reading the specs, it looks like it only excepts 1080i input?
Are there any scalers that take 1080P input and let you do vertical stretch?
True, it doesn't seem to support 1080p input - but (just to clarify for others) it does:
Supports the following popular Input Formats:
o 720 x 480i @ 60 Hz
o 720 x 480p @ 60 Hz
o 1280 x 720p @ 60 Hz
o 1920 x 1080i @ 60 Hz
Supports the following popular Output Formats:
o 640 x 480p @ 60Hz
o 1920 x 540 p @ 60 Hz
o 1368 x 768p @ 60 Hz
o 1280 x 768p @ 60 Hz
o 1400 x 1050p @ 60 Hz
o 1920 x 1080p @ 60 Hz
(The output frame rate will be the same as the input frame rate, and supports 60 Hz and 50 Hz input formats)
(see
technical specifications document).
CAVX
What sort of $$$?
Mark
The HDMI 4x1 switcher is $1000 (only available direct from their website I think?).
Here's a bit more from the manual, also from their website, re scaling:
"V Zoom (Vertical Zoom): This V Zoom feature is particularly useful for some
Plasma owners, who may want to stretch the image to fill the screen and avoid the
nasty burn-in. If the input signal is a Letterbox, Vertical Zoom extends (distorts) the
image from top to bottom to fill the screen. For example, it is very common for a
widescreen DVD movie to be presented in Letterbox, because the original movie
may be captured in 2.35:1 Cinemascope or some other Aspect Ratio that creates a
small letterbox in a 16:9 window."
From the RS-232 Commands section:
"Aspect Ratio - 0: Full; 1: Letterbox; 2: Pillarbox; 3: H-Zoom; 4: V-Zoom; 5: H-V-Zoom"
