AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Looking for a Receiver ~4-700
post #1 of 4
I am looking to buy a receiver. I have a samsung lns3251d. I want one which has multiple hdmi as I plan to buy a bluray and/or hddvd once things settle down a little bit. I would also like it to have HDRadio, but don't really care about xm or sirius compatibility. I would also like it to be able to upconvert signals through the hdmi. Can anyone offer some suggestions on models so I can do some research?
post #2 of 4
Onkyo SR-674 is commonly recommended for your need. Will cost 550 online.
post #3 of 4
Ok I did some research and I think I confused myself a little about HD Radio. HD Radio is publically broadcasted right? I see that it supports XM HD, but does it support general HD radio or are they the same thing and you need a subscription to XM in order to get it? (first time delving into the world of receivers)
post #4 of 4
I was wondering if there were any receivers in this range with similar features that would also allow me to hook up to my home network through ethernet?
This thread is locked
