AVS › AVS Forum › Display Devices › Rear Projection Units › Mitsubishi WD 52527 System Reset
post #1 of 5
I purchased a Mitsubishi WD 52527 last week. It was a display model so the initial setup had already been completed. I would like to know how I can reset it to go through the initial setup. Specifically I would like to disable Net Command so the device change button just changes devices without using net command (similar to my other older Mitsubishi HD).
What I have tried:
I pushed the reset button on the front screen.
I used the delete all inside the net command setup. (According to the manual this should make initial setup available but did not).
This is likely a simple procedure but I have been messing with it for more than an hour and thought I'd ask for help.
Thank you
post #2 of 5
bump.
Any help would be appreciated. I've searched these forums and the net for another hour this morning.
post #3 of 5
Have you tried calling Mitsubishi customer support?
post #4 of 5
I have a e-mail in to them. I didn't send it until Friday Morning though. Also have contacted my retailer. I'm exhausting every avenue I can find.
I just want to be able to press the device (up/down) button and cycle through the devices without going to a menu and having to press enter. My dad's mitsubishi that is 2 years older behaves this way.
post #5 of 5
man, this is a good question. I hope someone has the answer.
  Back to Forum: Rear Projection Units
