AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Sharp D62U Settings and Tweaks
Sharp D62U Settings and Tweaks - Page 3
post #61 of 1140
to program their Directv H20 remote so that you can use that instead of the Sharp remote for say, the volumn, screens sizes, etc. If so, what was the code you used (wife starting to get at having to use 2 remotes). Or, somehow, point me in the proper direction.
jw
post #62 of 1140
I am using a Harmony 880 remote. I added the Sharp LC46D62U and it seems to have most of the codes, including discreet input commands for all 5 inputs. It also has a bunch of commands that don't seem to do anything (like PIP-related stuff), so I'll have to go in and manually clean up the button mapping later.
On another topic: How does everyone feel about the noise reduction feature? I see there isn't much consensus on setting it to Off/Low/High. What type of sources is it generally good to use with? I turned it off for PC input at least. Does it generate unwanted artifacts when it's enabled?
post #63 of 1140
Even though I have a work-around, if anyone has been able to program input 5 in their MX-700 remote, please shoot me a private message so I can try to get a copy of your config. Don't really want to build my config around yours, just be able to program it to my sidekick so I can use it to learn with the main remote in my existing config. Thanks
post #64 of 1140
Originally Posted by TNG View Post
I don't know if this is connected, but when I change channels there is a abrupt darkening that is visible only because of the channel display. When the blank screen is replaced by the channel feed the brightness jumps back to where it should be. Not sure if this is just a function of the screen blanking or if there is a setting that will stop this.
My set does the same thing. Also somewhat bothersome is the slow response to channel up/down.
post #65 of 1140
Don't know why. Seems to have went away (for digital channels only) when I changed everything over to User settings. The analog channels still exhibit this dimming when you change channels.
Yes the tuner is very slow. Puts a crimp in my surfing.
On the remotes, I am using a Rotel 969. Works great, but it is a learning remote and it can be tedious teaching it.
post #66 of 1140
I was just looking at the manual pdf, and it mentions to use the HDMI connection for "full 1080p video". Now, I'll be using the VGA cable from an Xbox 360 - please tell me there's no issue getting 1080p from the VGA.
Please...
post #67 of 1140
Hi,
Does anybody know if there is a way to display the video signal format on TV channels? On other inputs (e.g. component) pressing "Display" button on the remote shows current input source and video format info; TV source shows channel numbers and current Audio/CC/Ratings, but not video signal format.
post #68 of 1140
I was under the impression the D62 didn't have a VGA or DVI-A port? So that would definitely be an issue
However it has been verified a couple of times that the D62 does accept component 1080p output from xbox360 after the update.
post #69 of 1140
Originally Posted by Sfrmid View Post
Hi,
My older Sharp display has 2 buttons on the remote. Display, which does what you describe, and "Info" which displays the incoming signal for the digital tuners. If you don't have the "Info" button, Sharp may have removed it on the more recent remotes, but there is a possibility the TV still responds to the IR. You'll need to get the IR from somewhere else though, either somebody else or if you have a programmable remote, through an existing device map.
post #70 of 1140
Hey all,
Just got my 25ft HDMI cable from Blue Jeans. I ran it to my laptop
(has an HDMI connection) and my LC-52D62U and fired it up. UNREAL
It took some time to realize how the NVidia mulitiple monitor thing works, but once I did everything worked perfect. I was able to play a 1080p Windows Media file "Stormchasers." I took some pics but they didnt come out. I may try to take them again tomorrow during daylight. I don't want to use the flash.
Being able to use this tv in dot-by-dot mode as a computer monitor makes it a great value in my opinion... lots of possibilities for lots of fun now
David
post #71 of 1140
Is anyone using a Harmony remote with the Sharp?
I have noticed that when the TV is off, and you start an Activity, it always fails to change the input on the TV. But if you press Help, it will retry setting the input, and then it's fine. I am using discrete input codes, and the Power On delay is set to 5000ms. What settings are others using?
I will try increasing the Power On delay, that seems to be the most likely culprit.. but 5 seconds already seems like a long time.
post #72 of 1140
I have a Harmony 659, had some problems with RF interference with my cable-box but that's about it
post #73 of 1140
I eventually got it to work. I had to set the Power On delay to around 7000ms, and the Input Delay to 3000ms. It's a bit slow, so you have to keep the remote aimed for a while longer, but it works. Too lazy to tweak it any more than that.
post #74 of 1140
Love the stream. Thanks to all who contribute.
I have the Sharp 42" and it has been amazing with HD broadcasts ( and recorded HD as well). As such, I wonder why mess with a good thing - but suspect there is sound advice here.
The factory presets have backlight on full - does that reduce life of set?
Secondly, it appears that people adjust for both TV and DVD - dumb question - in other words can you have seperate settings for each Input area?
Given only 10 days in ( 20 hours of viewing), is there an advantage to wait a certain period before making adjustments?
thanks
post #75 of 1140
thanks
Yes, each input is configurable with it's own settings (multiple settings actually using the different modes). As for waiting, I prefer to calibrate my set immediately so my eyes don't have too much time to get used to the out-of-box settings, which are always out of whack.
post #76 of 1140
I have the Harmonry 890 and was having the same issues when switching from watching the TV to Watch a DVD. I got on line with a harmony tech and he helped program the remote and we down loaded the changes. Everything works perfect now. Those guys at Logitec are very knowledgable and extremly helpful. It's amazing the when the new Sharps came out they had the codes ready to down load almost immediately. Try talking to support. I know they helped me.
Sam
post #77 of 1140
jw
Try the Harmony remotes. They are easy to program and their support is second to none. I have the Harmony 890, because it has the IR repeater so all my equipment is inside my entertainment cabinet and out of site. Works beautifully.
Sam
post #78 of 1140
I'm surprised you needed that much of a delay. I'm using just over 1.5 seconds with and RTI remote and it works perfectly.
CJ
post #79 of 1140
Having the backlight on at full I think will reduce the lifetime of the backlight. It is like everything, the harder you run it, the shorter it's life will be. I also agree with Ark, it is better to tone down such settings when you first get the set or you will get used to them. No matter what you do with your setting with color and tint, the backlight is the first thing to turn down.
For each input having defferent settings, in the service menu there are 6 different sets of RGB Gamma correction settings. So up to 6 different setups?
post #80 of 1140
I tried my "info" button from a "GA037WJSA" remote that came with my 37" Sharp LC-37HV4U a few years ago -- no luck! Most of the other buttons work, but not that one. Too bad... I'd like to be able to see the format of the incoming TV signal too. I helped a friend recently install a Panasonic plasma, and if I recall correctly there were 720p and 1080i labels displayed on the screen as we switched channels.
post #81 of 1140
Originally Posted by mydnyte View Post
my 42 is as follows (done with THX Optimizer DVD ...will do DVE config at a later date):
Input Source: 1080i Upconverted Pioneer DVD Player
AV Mode: User
OPC: Off
Backlight: -6
Contrast: +31
Brightness: -6
Color: +5
Tint: -2
Sharpness: -4
Color Temp: Med
Black: On
Noise Reduction: Low
Fine Motion: On
Thanks for posting this. I just adjusted my 42" set with your configurations and it looks great. Please let us know if you make changes down the road. My previous settings are below, but even though the changes are subtle yours look better.
AV Mode: User
OPC: Off
Backlight: -4
Contrast: +30
Brightness: -4
Color: +2
Tint: -1
Sharpness: -4
Color Temp: Med
Black: On
Noise Reduction: High
Fine Motion: On
post #82 of 1140
Help the newbie, please!!! We only watch DVDs--no cable/OTA, no PC, no gaming. So I'm hoping this will be a really simple setup!
Just got the 52" out of the box and before even powering up, I have 2 quick questions, keeping in mind that I will use this only as a monitor to watch DVDs from my old 480p Sony DVD player. I will hook up the component video from the DVD player to the 52" monitor and the audio will go via optical to my Rotel preamp and 5.1 surround sytem. Eventually, with the new 981 Oppo I will do HDMI from DVD to TV but will still route audio thru' the Rotel preamp. So:
1. How do I disable the Sharp's speakers? Will never use these.
2. If the DVD picture feed goes directly to the Sharp (via component or HDMI) and the DVD audio feed goes thru' the Rotel preamp, will there be a picture/audio lag problem? How do I fix this?
Ashley
post #83 of 1140
Ashley
Just a quick look though the menus and I don't think that you can "disable" the speakers. On the other hand if all you are watching is DVDs and from the player there is no audio feed to the TV, you should not have to worry about it anyway. Just turn down the sound to 0 and there you go.
As to the second question, I have not had this problem with any video/audio sytem setup that I have had since they came out with Surround Sound. If your DVD player is feeding both the TV and the Preamp and there is not another link for the signal to go though on the audio side then you shouldn't have any lag.
post #84 of 1140
Do you have the discrete code for Input TV working? I know I could just fake it by turning to Channel X, but I would like to get the real discrete code working. I have LC-52D62U and I have tried several different models of Sharp LCDs to get this to work and can not. I also emailed a request to someone within Sharp USA and have not heard back yet.
post #85 of 1140
Ashley
1. you can disable the sharps speakers --
in the menu navigate right to options
in options nav down to output select
on audio output settings, choose "variable", this disables the speakers
2. i have video from cable box and dvd going to sharp via hdmi and audio for both direct to a bose -- no sound lag at all
post #86 of 1140
i know this is for settings and tweaks, but if existing owners want to tweak their price, BestBuy and Circuit City just dropped (a/o 11/19) the 46 and 52 by $500, so if you're inside 30-days, they'll refund the diff
post #87 of 1140
Guess I should post this here instead of the banding thread where more people would appreciate it.
post #88 of 1140
More shots ...
post #89 of 1140
Final Set (for now)
post #90 of 1140
Yes the discrete input commands are working. I did not add any codes myself, I just put "LC46D62U" for model number when I added the new device, and in the list of commands there was "Input1" to "Input5" and I just mapped those to some custom buttons. You might want to try downloading the latest version of the Logitech Harmony software -- this is what I did first since it has been a while since I played with it.
Also when you setup inputs on the TV, and it asks you how you change inputs, just choose the "I press a button to directly change input" option, even though the Sharp remote does not have this. Then you can map those commands to the inputs.
