A Denon 3805 powers my 5.1 system. I have obtained a used NAD 216THX
2-channel power amp and am considering using it for the front mains.
What are some opinions on this? Will I notice appreciable difference using the separate NAD power amp (125w) vs. the Denon 3805 main amp?
Denon 3805 receiver
Denon 2910 dvd
Mains - Sony SS-TL6 (4-way transmission line towers) Early 90's
Center - Polk CSI5
Rear - Bic Venturi's
Sub - SVS 20-39 PC-Plus
Speaker Spec's from Sony
4-way
Enclosure type
Transmission Line
Rated impedance
8 ohms
Woofer: 20 cm (8 inches), cone type
Low-Mid range: 16 cm (6 1/2 inches), cone type
High-mid range: 12 cm (5 inches), cone type
Tweeter: 2.5 cm (1 inch), dome type
Maximum recommended amplifier power
150 watts (Non clip)
Characteristic sensitivity level
89 dB (1 W, 1 m)
Efficiency frequency range
30 Hz-27,000 Hz
Cross over frequency
150 Hz, 900 Hz, 3,000Hz
Denon 3805 receiver
Denon 2910 dvd
Center - Polk CSI5
4-way
Enclosure type
Transmission Line
Rated impedance
8 ohms
89 dB (1 W, 1 m)
30 Hz-27,000 Hz
