So I started playing with my iSync last night, but didn't get too far.
I bought this cable to go RGB out of the iSync to the 15 pin port on my plasma:
http://www.digitalconnection.com/pro...les/eehd5r.asp
The red, green, and blue hookups were obvious, but since I wasn't positive which leads were the H or V sync, I guessed and tried it. The picture was very, very green, so I shut everything down and switched the H/V sync wires. The picture was then very pink. WTF? The iSync analog output was set to RGB instead of the "Y Cr Cb" (or Pr Pb) option. Despite the pinkish picture, I continued to mess with the settings. I tried the 1366x768 output, which is native resolution for my set and I got no picture with that setting.
Any ideas on what I did wrong?
Another thing I noticed is that the analog output doesn't seem to be active if there is a cable plugged into HDMI out...that's lame, though I understand why it works that way.
Later,
pjdavep
