AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Is there a wall plate remote, so I can get music from my receiver downstairs?
post #1 of 3
I would like to install speakers in a room upstairs and run speaker wires from my receiver in the basement. Is there a wall switch that would let me control the functions on my receiver?
Thanks Vid53
post #2 of 3
yes, you can do this with a RF remote. Or if it is wired with an IR window. Lots of other options but those are the cheapest. Make sure that your receiver is a multizone receiver. Or just put them on speaker B.
post #3 of 3
Look at Russound K2 IR keypad, it is a in wall universal remote, all you need is run a cat5 or shilled control wire to your equipment location.
Mark
  Back to Forum: Home A/V Distribution
