AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Plasma advice needed
post #1 of 19
So I am new to the AVSforums and to plasma TVs in general, but have decided it may be time
I am looking at 50" plasma TVs and have a budget of not more than about $2K.
It looks like the hot deals are on three major TVs (that are from brands I recognize anyway.) I thoughth I would throw them out along with the rumored prices to let you more knowlegeable folks give me your two cents.
1. Toshiba 50HP66 At Best Buy ~$300 less Must wait in line for a chance at this one too.
2. Panasonic TH50PX60U at Circuit City for ~my budget
3. Vizio P50HDTV10A ~$500 less after $200 rebate, and a wait in line too.
I will be runinng this with a nice THX system at a viewing distance of about 13-14 feet in a semi dark room. I will also be looking at a HD DVD player and the upgrade to my DirectTV system to use it correctly. Primary viewing is DVR TV and Movies at about 50% each.
My brief research led me here and suggests the Pannasonic may be the better choice but the Toshiba is a great deal cheaper. I have never heard of Vizo but the feature list seems deeper.
On a related note, the websites seem to comflict on what resolution is supported, can you clarify if these TVs can do any 1080 modes natively? That would make a deal breaker as I am hoping to be future proof for the near future.
Thanks in advance!
post #2 of 19
Let me add, I am sure each unit has its strengths. Good info lurks here after all, but I am really interested in the price vs performance aspect. If I am going to waste my morning+ waiting in the cold, I want to feel it was worth it!
post #3 of 19
Don't forget, $200 rebate on the Panasonic.
post #4 of 19
post #5 of 19
If there is a $200 rebate on the panny, AND no line waiting... no brainer, go with the panny. Even if you have to wait in line for all (so that's not a factor) the panny is still the best choice.
post #6 of 19
Edited the prices out! My bad. I thought rumored prices might be OK.
Thanks for the hot tip on the Panny rebate. I will check it out now. That will definately point me in that direction and skip the lines too.
post #7 of 19
None of those 50" plasmas do 1080p native, they're all 1366x768. 1080p native plasmas are just starting to enter the market and are quite expensive. With your viewing distance (13-14'), 1080p on a 50" screen is arguably not going to produce a discernably better image than 720p.
post #8 of 19
Thanks for the clarification. Is there a reason the specs would show 720p and 1080i on some sites but only 720p on others?
post #9 of 19
Depends on what they are quoting... the ones listing 720p only might be showing native rahter than supported input resolutions. I would also agree with above 12-13" seating distance means you will probably NOT see the added detail a 1080p set would provide.
post #10 of 19
So it seems like I will probably not miss the 10880p based on my viewing and price!
So now I am wondering about the Toshiba at a lower price. A quick search reveals tons of members have the Panny but I can't seem to find many owners sharing the Toshiba experience? Is this the subtle clue I need?
Also the rebate semms like a good excuse to have CC deliver and set up my unit. Does anyone have experience with the CC setup? I am pretty technical and feel confident I can get things setup and calibrated based on the advice given here. Or is this unadviseable due to warranty issues with my own delivery and setup?
post #11 of 19
check out the panny 50px9uk--if you don't need stand/speakers--can buy it for visual apex and dtvcity--both GREAT online dealers with great cust svc--<2000$, plus rebate i think, plus free 5 yr warranty. the panny 50px60 also is very cheap at dtvcity--if you need the consumer model. also check out tvauthority and clevelandplasma--both authorized online dealers with great cust svc-esp chris at clevelandplasma jeroldd
post #12 of 19
Check out the 50px60u at CC on that day.
post #13 of 19
please keep this to what to buy, not where to buy
And please, no black friday discussion either.
thanks all
post #14 of 19
NrKissed,
You have a PM.
post #15 of 19
The $200 rebate is only for the install of the plasma. I called panasonic today and thats what they told me.
post #16 of 19
Well with the CC install prices, I am pretty sure the Toshiba is winning the budget wars. The $200 rebate is only for installs and I will not be wall mounting at this time. (Wrong Room shape!)
I know the Panny seems to have the better picture acording to the forums majority bit it just isn't comnvincing me it is worth the differernce in $ on BF.
I will keep my eyes open until the BF prices are a reality early next week.
post #17 of 19
To install also means..to bring set inside the home and set it on a stand.
post #18 of 19
NrKissed, I spend about an hour playing with the Toshiba model when it first came out. While I could go in depth with everything I did, the most significant test I ran was hooking up a Toshiba HD-A1 to it with a demo disk that showed multiple HD trailers. To sum it up, I was very disappointed. The picture was soft and there was some significant banding that was definitely not coming from the player. I would stay away from that TV.
post #19 of 19
So I ended up with a Toshiba 50hp66 thanks to the Best Buy deal. I go the last one!
My first impression is it looks great. I had purchased a RCA upconverting DVD-R in advance through woot.com and with the HDMI signal the picture blows away my older Toshiba player. Today I am having my DirectTV upgraded to the Hi-def DVR and hope to see a similar improvement in my normal TV. (Or at least some new HD channel options.)
I do notice the default color calibration is a bit washed out towards an orange tint. I would love to learn how to do this myself. Can anyone post their setings on this model to give me a starting point? I am curently looking at a couple of commercial Calibration DVDs but I confess I have just started to research the picture tuning aspect of owning a Plasma TV.
Thanks for the help and discussion. I am sure this will be the source of hours of entertainment.
This thread is locked
