On a whim, i took the Dell Precision M6500 running Ubuntu that I use for work, attached a display port to DVI adapter and a DVI to HDMI cable and it did true plug and play and worked instantly.
Here's what linux reports as the timings:
I've tried to derive what I think the porch values might be from that range, but i haven't succeeded in getting it to work.(--) Jul 11 21:52:54 NVIDIA(0): --- EDID for SHARP HDMI (DFP-1) ---
(--) Jul 11 21:52:54 NVIDIA(0): EDID Version : 1.3
(--) Jul 11 21:52:54 NVIDIA(0): Manufacturer : SHP
(--) Jul 11 21:52:54 NVIDIA(0): Monitor Name : SHARP HDMI
(--) Jul 11 21:52:54 NVIDIA(0): Product ID : 4126
(--) Jul 11 21:52:54 NVIDIA(0): 32-bit Serial Number : 0
(--) Jul 11 21:52:54 NVIDIA(0): Serial Number String :
(--) Jul 11 21:52:54 NVIDIA(0): Manufacture Date : 2008, week 255
(--) Jul 11 21:52:54 NVIDIA(0): DPMS Capabilities : Active Off
(--) Jul 11 21:52:54 NVIDIA(0): Prefer first detailed timing : Yes
(--) Jul 11 21:52:54 NVIDIA(0): Supports GTF : No
(--) Jul 11 21:52:54 NVIDIA(0): Maximum Image Size : 820mm x 460mm
(--) Jul 11 21:52:54 NVIDIA(0): Valid HSync Range : 15.0 kHz - 75.0 kHz
(--) Jul 11 21:52:54 NVIDIA(0): Valid VRefresh Range : 23 Hz - 76 Hz
(--) Jul 11 21:52:54 NVIDIA(0): EDID maximum pixel clock : 170.0 MHz
(--) Jul 11 21:52:54 NVIDIA(0): Detailed Timings:
(--) Jul 11 21:52:54 NVIDIA(0): 1920 x 1080 @ 60 Hz
(--) Jul 11 21:52:54 NVIDIA(0): Pixel Clock : 148.50 MHz
(--) Jul 11 21:52:54 NVIDIA(0): HRes, HSyncStart : 1920, 2008
(--) Jul 11 21:52:54 NVIDIA(0): HSyncEnd, HTotal : 2052, 2200
(--) Jul 11 21:52:54 NVIDIA(0): VRes, VSyncStart : 1080, 1084
(--) Jul 11 21:52:54 NVIDIA(0): VSyncEnd, VTotal : 1089, 1125
What's even more infuriating is that i tried maybe a dozen or so different resolution choices in linux and the TV supported them all.
Am i missing something completely fundamental here?
