AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › Pio 425CMX w/ HD Xplorer vs Pan 42PH9UK - help me decide!
post #1 of 31
Hi All !
I've had my 3 years with my Samsung EDTV 42" plasma - bad support, monitor noise, poor blacks and bad definition have led me back into the market for something better with a more reputable company.
So - to cut a long story short, I've been doing a lot of reading and I think narrowed down to 2 options (unless somebody has some more advice). I think that, given my viewing distance, all I need is a 42 inch set (unless, again, you think otherwise), my main inputs are DVI from an Oppo Dvd player, and HDMI from my HD Tv which I currently switch into Samsung DVI input. I need a clean lines, quiet monitor with no bells & whistles, but I really would like good picture quality, blacks and such.
I am torn between the Panny 9UK with DVI blade & stand, or the older generation 425CMX but with the price-reduced HD Xplorer card. I know the Pio has double glass and does not match the consumer 7 series' performance (and 50" commercial 7). However, how does it perform with the Xplorer card, and is this a good match?
Any advice very greatly appreciated.
post #2 of 31
The Panny 42PH9UK beats the Pio 425CMX in pretty much every way, especially in blacks.
Remember you will probably want to add a connectivity blade or two to the Panny (and the Pio CMX would require a video card also). When you factor those in, you are getting close to the price of a NEC monitor which you might also want to consider: NEC 42xr4a or 42xm4a (consumer/industrial). In the same price range would be the Pio 4270 with all the bells and whistles (tuner, speaker, etc).
post #3 of 31
I wish I had a good answer for you, as it is a question which has been plaguing me, as well. The problem is, not many people here have seen the 425cmx in action, whether it be with or without the Xplorer card. I have yet to see a single "professional" review of this panel either.
Certainly without the card, the Pio 425cmx is said to be inferior to the Pannny 9UK when it comes to black level. Now, how much less, I don't know. Is it close for all but the pickiest viewer? How do the 425cmx blacks rank amongst other brands, such as the latest Samsungs, Hitachis, etc., of this world? Similar? Still better, just not as good as the Panny? Good questions, all.
Also, whether the Pio black levels would improve substantially enough with the introduction of the Xplorer card, I do not know. My sense is that they will not improve, though almost everything else will, i.e., color fidelity and vibrancy, processing, etc.
Chris from Cleveland Plasma, a forum sponsor, has provided some casual observations about this model, and how it might perform with the card, but I don't think even he has spent much time comparing and evaluating it.
Also, the 427CMX replacement model in the 42" is said to be on the way, but that could be several months yet. At least, I haven't found any concrete information about this new model anywhere, when googling for it. This suggests to me that we are some ways away from seeing it. I'll be curious to know if this model will be adopting the single layer glass, just as the latest 50" Pio commercial models have done (I would assume that it will have it). Bare in mind, neither the 425CMX, nor the Panasonic 9UK have the single layer glass.
As a side note, I noticed from reading some specs that the 425cmx only puts out a maximum of 285 watts. I think that's even better than the 9UK, which isn't too shabby in that dept. itself.
Dusufyte - where are you drawing your conclusions from? I'm just curious.. have you compared the two yourself, or have you read opinions from someone else? If so, are they multiple opinions that come to those same conclusions? Just wondering.. I'm hoping for a little context to your observations.
post #4 of 31
furthermore..
I'm not sure this is valid anymore. The price on the 425cmx came down a few hundred in the last month or so. From a reputable seller, such as Cleveland Plasma, and maybe others now too, you can purchase the 425cmx for a price that falls within $100-$200 of the 9UK. Even after adding a card, maybe two, you would still be at least a few hundred away from the price of a NEC 42xr4, and probably still a couple hundred more beyond that from the Pio 4270.
post #5 of 31
Hi - thanks for the responses.
Re. the blades, I _do_ like the array of inputs the HD Explorer gives me also right out of the box, and that is somewhat attractive as is the ease of use of the card for configuration. With the Panny I am either stuck in switcher land (which I'd love to leave completely!) or racking up on the blades. Unless there is another high quality multi-input option ?
The blacks bother me a little yes, but I just want more definition across the color range, if that makes any sense - perhaps I stated things incorrectly.
I'd _love_ to hear somebody give a review of their 425CMX though, rather than buy blind. With or without HD Explorer card.
And even the 7th gen Pio vs. the Panny would be something I'd be interested in reading, even although former is way overpriced.
Re. the NEC - I'd been reading about this panel also as I believe they share Pio glass ? My impression was the picture quality was nothing to write home about on the 42xm4a however - is it single pane glass generation ?
Thanks all
-g.
post #6 of 31
The 425cmx monitor itself is a great price, but when you add on the video card plus a stand/mount, it is getting close to a Pio 4270 which has all these things included (plus speakers).
The 425cmx just came out recently, so I do not think a replacement model is coming out until late next year.
I have never seen a 425cmx in person (nor a 9uk for that matter - shame on me) , but I report the concensus of reviewers who have seen them. The 5th gen Pio blacks in the 425cmx would be a step behind the 9uk for sure. Pio made great strides in their black depth on the 6th gen glass.
post #7 of 31
Go Pioneer all the way the PDP-425CMX has a wonderful price point right now, and it is the new generation glass. Pioneer's 6th generation or last years models were all cut in the 43' size not the 42" size.
I hear a lot of people say that the Pansonic has better blacks, but the catch is that most people do not have a chance to see the 2 industrial units side by side since they are not sold in local store fronts. I can tell you that we offer both unit here in our Seattle, WA custom showroom and we have not had 1 customer say the Panasonic looks better. Panasonic does a really good job writing about their units and making them sound far better then any other on the market, but when it comes down to the side by side comparison with the naked human eye Pioneer will blow you out of this the water.
Go Pioneer, I have been in this industry for 8 years now and I can say with 100% confidence that the Pioneer will be a great addition to your system.
If you have any questions always feel free to send me a PM
Jamie
Invision Displays
A Forum Sponsor
post #8 of 31
Also if it were me purchasing at this point I would not waste my money on the HD card unless you really need all those HDMI inputs. I would start with the screen and then maybe ungrade in a year or so when they have perfected HDMI.
Jamie
Thanks all
-g.
post #9 of 31
My impression was the picture quality was nothing to write home about on the 42xm4a however - is it single pane glass generation?
The NEC 42xr4 and 42xm4 were the first panels to have the single pane glass. They are the same panel except for connectivity connectors (xm has dvi, xr does not) and bezel styling, and the picture on both of them is "a thing of beauty" as one poster in the long NEC thread wrote. The NEC panels are often equated with the Pio Elite line.
post #10 of 31
For Pioneer models, the third digit indicates the generation glass, so for a 425cmx model has 5th gen glass. Also the pdf brochure for the 425cmx indicates it has two panes of glass, and there is no mention of the bonded filter which would eliminate a pane of glass.
That said, I defer to Jamie as to the picture quality, as I have not seen one in person. Chris highly praised the 50" 505cmx, and that was also 5th gen glass, so I'm sure the 425cmx also looks quite nice.
but Chris also said the 50" 507cmx looks 10% better
post #11 of 31
I hear you, but I'm still unsure about the NEC 42xr4 model. As many good user opinions I've read, and positive "pro" reviews, I've read more wishy-washy "pro" reviews. I posed a similar question in the official NEC thread, with links to some of these reviews, but nobody was willing or able to negate some of the specific criticisms of the 42xr4 panel. The one that troubled me the most was the one or two reviews which mentioned "picture noise", with a subsequent recommendation that it's best if you sit at least 8 or 9 ft. away from the 42xr4 in order to avoid seeing the noise.
Granted, if you already own the panel and are happy with it, it doesn't then require of you to answer to each and every supposed flaw someone else has supposedly found. But I was hoping that someone would have come along, skimmed the reviews I linked to and chimed in with passionate defenses for some of the flaws cited in those reviews (i.e., "they're crazy! they didn't adjust such and such and that would have fixed the problem!" etc. ).
post #12 of 31
Thanks for comments on the NEC - I see they are down to approximately 2K and change now also.
I also had assumed that 425CMX was 5th generation given the third digit, so was surprised by Jamie's response - but if he has them in the store side by side with the Pan 9U's , then that is indeed something !
Is Chris from Cleveland around to add any thoughts ?
post #13 of 31
actually, he said 10% to 15% difference, depending on your preferences.
I believe you to be correct about the glass used in the 425cmx, unfortunately. I hope we are wrong on this. The easiest way to know the scoop is to check for the double pane of glass.
post #14 of 31
Even if the Pio were to have the single layer glass, the free Panny 5 year warranty upgrade (available through the end of the year) would still make the 9UK a compelling choice. On the other hand, the inability of the Panny to change aspect ratios for SD content on HD channels still bugs me a little. I *think* the Pio can do this, however. So can the NEC 42xr4.
decisions decisions.
post #15 of 31
Check out the illustration on page 3 of the 425cmx brochure. It shows two panes of glass, and no mention of a "bonded filter" or "first surface filter".
that's not to say it doesn't look nice
post #16 of 31
Jamie - have any additional feedback on the glass assembly on the 425CMX - is the brochure wrong? And any feeling on how much better the picture is with the HD Xplorer ? If answer is 'not much' then of course all I need is the basic unit as it comes with a DVI in (unlike the Pan).
i.e. if all you want is a DVI blade, then the cost of the 9U (+dvi blade) and the 425CMX is almost identical.
post #17 of 31
Does anybody on avsforum have a 425CMX ? Is the silence because they only recently have become available in the channel (a while after announce) - how long have you chaps had yours, Jamie ?
Am going to sleep on options tonight, and order tomorrow - same choice of 2 for me so far, and thanks to all for their feedback.
Does anyone care to pipe in on HD Xplorer experience with real world usage ?
-g
post #18 of 31
right - well I have costed out various options - Pio w/ HD Xplorer, Pio w/out & using builtin DVI & Panasonic both consumer and commercial 9U. Latter two options compare with the Pio/no HDXplorer. Pio w/ Xplorer is still about 600 $ more, all told.
So, last time I will ask before pulling trigger - does ANYONE here have a 425CMX? and if so have the side by side compared with the 9UK, both with and without the HD XPlorer ? (after doing setup)
post #19 of 31
I have installed a few PDP-425CMX with the HDXplorer cards, they look better with the card.
I have recently seen a problem with the RS-232 power off command when the HDXplorer card is installed, it does not work. Pioneer confirmed that they have seen this problem with 3rd party cards.
post #20 of 31
Thanks for the headsup - just to complicate matters further, I've decided to widen my options to include the 4270 as a possible purchase - the cost is very very close to the commercial older 425CMX w/ HD Xplorer, and the benefit is of course the newer gen glass and electronics as well as inputs. It is definitely considerably more expensive, but I've heard such good things about it and the way it looks....
post #21 of 31
^^^^ Were are you Shopping? 425CMX and Key card is way less than the 4270HD. Tough choices out there with the Pannies having a 5 year warranty included. The 425CMX and the Key Card will be better overall than the panny but you will pay a little more for it. You will have a ton of inputs too. If the key card is not added, its the old Panny VS Pioneer saga.
post #22 of 31
Hi Chris - thanks for the prompt reply !
Yes - it is hard to argue with the Pannies, particularly the home units with bells & whistles at their current price point. From anecodotal evidence I think that the Pio (4270) would be a good panel for me, though, and at around a couple hundred or so difference from an older generation 425 w/ HD Xplorer to the bang up to date 4270 I think it is probably correct for me to just take the hit on the cost for the most recent panel.
This has been a very informative week or so, and thanks to everyone for helping me out btw.
-G
post #23 of 31
Jamie
The HD Xplorer card is about more than HDMI connections. The card has a top notch scaler on on it that turns the panel into a Pioneer Elite picture quality. As Custom installers in Cleveland we have seen it with our own "eye's" . There was a huge price drop on PDP-425CMX also.
post #24 of 31
Thanks to this forum!
I am also in between 3 models panny phd8uk (used), ph9uk, and pio 425cmx.
if I understand correctly, pio has only 2 inputs out of the box: analog rgb and digital dvi-d (both for computers) - is that correct?
If we would like to watch TV/dvd on Pio there are two alternatives:
1) Buy a PDA-5003 or PDA-5004 card (PAL and NTSC support without any dvi or hdmi connect) or HD xplorer card (PAL and NTSC support with 4x hdmi+ component + better pic quality).
2) use a pc with tv card and the dvi-d output for digital signals.
And, in general, can we assume that pic quality is on par between panny and pio commercial units?
Any known blown power supply issues for 425cmx (like older models)?
Thanks kindly!!
post #25 of 31
good questions.
The collective board wisdom seems to suggest that the Pio will have more color pop/vibrancy, followed by slightly better scaling/processing (esp. with KeyDigital card), and the Panasonic will have deeper blacks, along with a cheaper price and better warranty (9uk). But yes, both pictures will be very close and very pleasing, so price/warranty/features should probably be your determining factor in choosing one over the other.
I'm still considering both. Probably leaning Panasonic because of price and warranty, but Pio is still very much in the running (depending how much key digital card is running). One way or another, my self-imposed decision deadline is 2-1/2 wks from now (between Christmas & New Years).
post #26 of 31
Don't want to mess with forum rules, but you might find that the price for the 425CMX is on target at a well known BM/online retailer. PM for full details.
post #27 of 31
Hard to believe for the first time Pioneer is cheaper than Panasonic on a product.
post #28 of 31
Is it true what Lex vs Kingpin said? That I'll need to buy an expansion card before I can watch TV on it through my cable box? Or can I just plug it into the unit's dvi port? I hear that the 42PH9UK will work out of the box with a cable box unsing component connection.
post #29 of 31
That is true. Pioneer has a way of locking the DVI port(except for computer use) until you put at least the Pioneer PDA-5004 Card in it.
post #30 of 31
I have the PDP-425CMX. Currently my DVD player have a HDMI port. And I would like to use it the plasma"s DVI-D port. Does any one know which type of cable do I need?
Many thanks
