I know this question has been asked before, but I couldn't find my answer.
I have my PS3 connected via HDMI and then my TV to the recevier (H&K AVR55) via optical. I decided to rewatch some Band of Brothers, which have the DTS-HD 5.1 audio. My current settings were not working, so I tinkered until I could get them working.
On my PS3, I had to switch from bitstream to LCPM under BD/DVD Audio Output Format (HDMI)
On the receiver, it will only play with Pro-Logic and not the Dolby digital setting, which had worked with all other Blurays and my connected PC.
I want to be able to play that bluray with the dolby digital setting turned on, on my receiver. Is this possible? When I was tinkering, I could get the menus to play with sound, but not the actual episodes. The aforementioned setting was the only one that worked.
I'm updated to 3.72 on the PS3 and noted that on the 3.70 update "DTS-HD MA, DTS-HD HR decoding/bit stream output (or lossless audio) will be supported while playing Blu-ray 3D movies." But I'm also reading that "fat" PS3s do not do this.
I'm a little confused. Help!
and they recommended that once the player has shut down to flip the switch above the power cable off for two minutes then switch it on and try again . Short story it worked .
