Originally Posted by rnjrusso
I have a Sony KDSR60XBR1 that outputs in 1080i, not p. When I hook up the PS3 thru HDMI cable, nothing happens. Screen stays black in Video 7 (which is where the HDMI cable is plugged). I can hook up the PS3 with the red, white, yellow cables it comes with.
Called Sony and they told me that I cannot hook up PS3 into the 1080i, that I have to purchase a 1080p TV because Blu Ray does not work in 1080i TV's. However, I have read that people are able to do it.
I know the cable works and I know the HDMI port works. Currenty have DVR set up with HDMI.
By the way, it's my brother's PS3 that works fine in his 1080p TV. Also, I have rebooted the PS3 to get the regular cable to work. I just can't get the HDMI cable to work.
Does anyone know what I have to set in my TV and what I need to set in the PS3 to get it to work?
You got bad information from Sony because that is entirely incorrect. Blu-ray works on 1080i TVs. All of them.
The default video setting on the PS3 slim should automatically select the 1080i signal for your 60XBR1 as it does for my 50XBR1. If it's on "Auto," even if you choose 1080p, it should revert to 1080i after 30 seconds...kind of like a computer monitor sometimes does when it's "out of range."
The only think I can think of is perhaps this PS3 was previously connected to a 1080p set (your brother's??) and MANUALLY set to 1080p. If so, take it back over to his house, hook it up to his TV, and set it to back to "automatic" or 1080i.
Then call the fool you talked to at Sony and tell him he isn't qualified to answer the phone.
