AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › JVC DLA-RS1 questions answered!
JVC DLA-RS1 questions answered! - Page 109
post #3241 of 3254
Originally Posted by legolas_fr View Post
I mounted my HD-1 with this
http://www.erard.fr/fiche_produit.ph...&cat3=2&cat4=1
Excuse me for my poor english
Seems like perfect english to me.
post #3242 of 3254
legolas_fr
thanks
I really need a wall mount because my screen has been there, very far away from the ceiling, say some 50 inches. I need either a wall mount. After all, I also find the HD-1 does not come with keystone adjustment
post #3243 of 3254
Are there any large chain stores or web retailers carrying this projector or the DLA-HD1? It seems hard to locate.
post #3244 of 3254
Where are you located?
I visited a local store that said they had three in stock.
Don't know if you are in my area, though.
Doug
post #3245 of 3254
Doug
Hi Doug, you and other local members are welcome to come and check out my RS-1.
post #3246 of 3254
Kthacher
I am a new recipient of the RS1 now yippee ! I never noticed any degradation on SD video up conversion to 1080i over HDMI after the 1.3 firm update. I just updated to FW 1.5 three days ago on the XA2 . Like yourself I am more of a novice user. I find the RS1 to be everything I expected and then some. I posted my initial impressions in the users thread.
I used the XA2 with a HS-10 before the RS1 upgrade and it seemed head and shoulders above the HD-A1 in up conversion. It has really paid off for me as I dropped using TT and my HTPC for DVD. Still use it for HDTV with the MyHD 120 card at 1080i and it looks stunning on the RS1 ! Johnathan
post #3247 of 3254
johnathan, how did you manage to get ahold of an RS1 from AVS right now?! We're supposed to be inbetween shipments--shipment 2 is long past, eagerly awaiting shipment 3...
post #3248 of 3254
He (johnathan) answered that question here.
post #3249 of 3254
Pedro
I don't have any info on how many were held back but in the old post on shipment two Jason explained that some of the 2nd shipment people that ordered early of the 20th would be receiving them in due time.
Thanks Mike for the link.Pedro this is the 3rd week of the month so maybe there will be another batch in the pipe line soon for the rest of you. At least according to Tom Stites in another post they release them monthly. Being in the second batch has payed off with a firm ware update. So good things do come to those who wait ! Johnathan
post #3250 of 3254
Wow
Another thread cooled ! Four day's and counting ha ha. Cheers Johnathan
Five days and counting
Six days ***********
Nine day's **********
Ten day's ***********
post #3251 of 3254
There has to be some irony in the fact that after waiting months for a few JVC DLA-RS1 projectors, that I may be "stuck" with promises to purchase two machines that I can no longer use. In case you haven't gotten one from AVS forum (note that this wonderful place should be your first priority, as I would never step on their toes!), then you might want to email me here or better yet at sms@bee.net to see if they are still available by the coming week. Hope everyone is happy with their new projectors and also that many guys will be satisfied soon, as I see delivery on most has finally happened!
post #3252 of 3254
Wow, reviving this thread--what a "flash from the past." This one really helped get all the RS1 buzz going. JVC should give it an award.
post #3253 of 3254
Yep!
I recently bought an HD1 (RS1). After reading and reading about projectors. Yes, Its my first projector and I spend on it all I had >.<. It looks good but, I've a problem with it, altough. I'm using an ASUS 8600GT graphic card to feed the projector and I can't get the 1080p. 1080i and 720p works but 1080p not. I've tried the timings posted a few replies ago, but I get a partial color image and the rest black. I think the aswer is in the custom resolution pannel but I don't wan't mess with that more without more info. Is there any solution?
I'm using forceware 163.71. (and nvidia control pannel to change resolutions)
This is the video card.
Thanks for your time and merry christmas!
post #3254 of 3254
Originally Posted by calamarcillo View Post
Yep!
1080p should work fine with the default (non-custom) settings. I've used the RS-1 with an HTPC and it worked fine. Programs to set custom timings like powerstrip aren't really needed. I'm surprised that 1080i works and not 1080p because usually PC's have the opposite problems (progressive is easier to setup than interlaced).
One thing to check is the monitor type that is being selected when Windows boots and checks the video ID bits. If Windows doesn't think you have a 1080p compatible monitor (the RS-1) it will try to use lower resolution settings like 1080i and 720p.
