So i want to attempt this. I've read a ton and my head is spinning. Hopefully you can answer some of my questions. Any hand holding is appreciated
1 - I see the ingredients, but i'm not 100% certain about the recipe. What do i mix to what in which order? Can somebody spell it out for me so i don't mess it up? In other words - Step 1, do this, step 2, do this etc.
2 - How much paint will i end up with using the ingredients listed? As in - enough to cover a 8x4 sheet? Do i need more paint? (I assume it's better to make more paint ahead of time.)
3 - Once i have it mixed, i need to do some sort of straining / thinning apparently to get it to the right viscosity. Can somebody spell out what tools i need for this and what to do exactly?
4 - The actual spraying: While i have seen the videos with the technique, i'm not certain about the surrounding / supporting stuff. Like - I'm supposed to spray some light coats with time between them. Having never done any spray painting, i do not know if / what all i should do with the paint and spray gun etc during that down time. Do i need to put the paint back in a can and clean out the spray gun completely between each coat? If so, what's the best way to do so? Assume you're talking to be a total newbie here.
5 - Can you confirm the number of coats, type of coats and time between coats for me? My head is kind of spinning with all the info, and i'm not certain about this part anymore.
