Materials available at Michaels Arts & Crafts or most any Artist Supply or Hobby Stores.
Last Updated: March 23rd, 2009 Edition:
"SILVER FIRE"
* use 3 oz. of the 'color components' and add/mix it to the 'base & viscosity components'
(base components)
30 oz. Delta Ceramcoat Pearl #02601
15 oz. Delta Ceramcoat Silver Metallic #02603
10 oz. Behr Interior UPW Flat #1850 (or Exterior #4050)
6 oz. Folk Art - Champagne Metallic
(viscosity components)
24 oz. Minwax Polycrylic - Satin Finish @Michaels & Home Depot
12 oz. Distilled or Filtered water
(color components)
50 ml water to rinse the color pigments from the measuring utensils.
20 ml - Liquitex Basics - Naphthol Crimson - (PR170)
10 ml - Liquitex Basics - Phthalocyanine Green - (PG7)
6 ml - Liquitex Basics - Primary Blue - (PB 15:3)
6 ml - Liquitex Basics - Cadmium Yellow Deep Hue (PY 83)
Silver Fire - L (Lite)**
** use 2 oz. of the 'color components' and add/mix it to the 'base & viscosity components'
Silver Fire - SL (SuperLite)***
*** use 1.25 oz. of the 'color components' and add/mix it to the 'base & viscosity components'
"SILVER FIRE HG" (High Gain)****
(base components)
36 oz. Delta Ceramcoat Pearl #02601
12 oz. Delta Ceramcoat Silver Metallic #02603
8 oz. Folk Art - Champagne Metallic
7 oz. Behr Interior UPW Flat #1050 (or Exterior #4050)
same as above
(color components)
same as above
**** use only .75oz of color components.
here's any example of how the color components and completed mix should look.
on the left is the 'color components' before it's added.
on the right is a completed silver fire sl mix.
Well aLrIGHtY tHeN.
Just mix to the ratios provided on the rest of the illustrated Post and off you go....right where you really want to be.
"SILVER FIRE"
(base components)
(color components)
(base components)
same as above
(color components)
same as above
Well aLrIGHtY tHeN.
) with nothing needed except a good stirring and restraining. The water will make it separate but no harm comes of that.
