AVS › AVS Forum › Video Components › Home Theater Computers › Do NVidia 7900GTXs support 1:1 mapping on Sony V2500s?
post #1 of 10
After my experience with the ATI x1900xtx and underscan on my Sony KDL-46V2500, I am considering getting a Nvidia card.
So, could those of you using these cards and getting 1:1 please post your results and which 1080p LCD you have?
I would really appreciate it.
Best,
Jeff
post #2 of 10
I think you mean 7900GTX. The 6900GTX doesn't exist
post #3 of 10
Yes, thanks for pointing that out buddy.
post #4 of 10
The 2500 doesn't due 1920x1080 on vga.
and you shouldn't use hdmi or any other for pc.
read the manual
post #5 of 10
read the manual
I'm looking for a little clarification here.
the manual says NO. But I've heard of it done (namely with a mac mini and their tweaking programs) on the KDL-40v2500 over HDMI.
Can someone please clarify. I'm looking to construct a HTPC with my KDL being the pri monitor, and I don't want to be "stuck" with vertical bars on either side if I use the RGB connection...
Thanks gents.
post #6 of 10
I have my 40v2500 hooked up via DVi to HDMI cable, 1080p no problems what so ever. TV has an option for 1 to 1 pixel mapping. My vid card is geforce 6800. TV is Japanese
post #7 of 10
I have a 40V2500 with DVI to HDMI on a 7900GS running MCE at 1920 X 1080P 1.1. No problems for over 3 months.
post #8 of 10
When I threw up the image on DVI-HDMI connector @ 1920x1080 the image did NOT look as good as my wife's lappy (using RGB connection) @ 1400x1050. It was also overscanned to about 1 inch all around past the screen edge.
I'm running an NVIDIA 7800GT, not that that should matter except in tweaking utilities (nvidia vs ati control panels).
Workarounds, things I haven't tried?
Thanks for the tips thus far.
post #9 of 10
The reason it doesnt look good and have overscanning is because you need to change the setting on the TV to use full pixel mode. This turns on the 1:1 pixel mapping and every single dot will be pixel perfect/razor sharp. You should check out the AVS Forum thread for getting the colors calibrated perfectly here:
http://www.avsforum.com/avs-vb/showt...4&page=1&pp=30
post #10 of 10
please school me then, how do I make it 1:1??
-EK
