With not much of a choice we had a DS3s mounted on rear wall. The SR speaker is fine but the SL speaker is too close to the side wall ( almost touching it). I am able to hear the SR speaker but not much from the SL speaker. Both the speakers are in dipole mode. I tried mono pole which is a bit better but still not yet there.
The option that I want to try is to increase the channel volume on this speaker and match it the SR but just wondering if this is good to do? My Audessey multixt keeps marking this left speaker at lesser volume all the time.
Is there anything I can do to improve the situation other than buying a pair or CM1/CM5 and keeping them on stands - which we thought many times over and ended up getting DS3s.. My fronts are CM9/CMC2.
Regarding the amp, I pretty much decided to go with either xpa3 or xpa5 and started saving.
Think about all the dust you remove from your speakers every week. Really want that on your drivers?
