AVS › AVS Forum › Audio › Speakers › B&W Owner's Thread
B&W Owner's Thread - Page 399
post #11941 of 13894
Originally Posted by ap1 View Post
In bananas - no. The weak link is a contact between banana plug and socket. I know that some devices have locking nuts that locks plugs in sockets, but this is uncommon.
Do you any more info where i can read more about this?
Try to Google "contact resistance", and you may find something you can understand. For me it was part of study for EE degree in university.
My question, and I mean this legitimately as a question, can you hear it? If we did ABX testing, could you pick out banana plugs vs. bare wire more than, say 65% of the time? Or is it more of an issue that you don't want to bother with the potential of a problem in exchange for a rarely used convenience?
post #11942 of 13894
Anything more that 80 may result is hearing subwoofer as separate entity. For 805D I would try all available setting in the range 50-80 to see which works best.
I'll say this, I had my HTM2D2 set at 60Hz and it experienced issues with a few movies and it is a more low frequency capable speaker than the 805 and HTM4 so in fear of risking damage to the 805 and HTM4 I suggest nothing lower than 70Hz with those.
post #11943 of 13894
Originally Posted by petetherock View Post
It's a bit hard to get the 804S to compare, what do you mean by the 804D blows the S?
Refinement, detail or bass?
I see a lot of people use the Classe, but that's a bit rich for me.
I might be able to get my hands on a MC 8207 in my place cheaper, so I am looking at that, or continue with the MF series, which is more expensive but seemed to match well with my 805s.
the "D" was more accurate in bass area, with better presentation of the vocals (I assume that new xover have the fault here) and the tweeter diamond is in one word: perfect, I like that my music sound like it should be and the sound of the 804S although is good sadly is not in the same league like the 804D. I have the 805D too so I think with them you will have the same result if you compare this with the old version.
post #11944 of 13894
Probably not immediately. After year or two contact may degrade to the point when you be able to hear it (or you may experience complete failure with one channel silent until you re-plug it again).
post #11945 of 13894
Originally Posted by Paraneer View Post
Very simple....I would buy the pair of speakers that sounds best to you that you could afford. In this case, sounds like you can afford the CM's because you already have them and you find them to sound better, even if it is ever so slightly. You never said the Polks sound great, you just mention their great price.
If you don't go for them now, and buy the Polks because you are being motivated by a savings, everytime you listen to them, you'll be asking "what if I kept the CM's?. Its called buyers remorse, usually motivated by a need to save money and not necessarily get what we really want. And worse, you may find yourself upgrading back to the CM's and costing you even more money rather than doing right the first time.
So to repeat...if you like the CM's better and can afford them, these are the ones you should keep.
You are right in all aspects.
post #11946 of 13894
I'd never consider the Polk even if they were $50/pair. I don't like them very much and my wife has a worse opinion of both their sound and aesthetics. Now if I had your ears, your bank account, and your taste, I'd probably go with the lsi15 and add a solid sub to handle the bass.
Thank you for sharing your thoughts!
post #11947 of 13894
Are the B&W speakers the best in the world? They are the most famous high-end speakers as far as I know. I own a pair of the 800 series for many years, and they are still great! smile.gif Can you tell me which speakersbrands are better? Is there a upgrade possible or are the 800-series B&W already the best there is.
post #11948 of 13894
i busted one of my diamond tweeters on an 804.
can anyone tell me the standard operating procedure on what to do here?
post #11949 of 13894
I had a broken tweeter on one of my 804 diamonds when I took delivery. I called the dealer and they had me bring in the broken tweeter parts (to return to B&W) and they promptly repaired it under warranty. If it breaks within the warranty period, you may have a case for replacement. Otherwise, I understand it's about $1100 for the part alone. Keep us advised.
post #11950 of 13894
Originally Posted by leo2498 View Post
have you thinking in get a better preamp? maybe emotiva if you budget is narrow, I will change my denon AVR3310 for a dedicate two channel preamp because with some preamp that I tried in the past, my 804D really sing and normally with my 200 W amp I don't have the same result.
I'm not sure about needing a new preamp at the moment, the rxa2020 is pretty capable, and if I were to upgrade I wouldn't go with an Emotiva, just me. I'm thinking the PM1's need better power than what the yamaha can provide, hoping for suggestions here
post #11951 of 13894
yeah, i called a diamond dealer and bought a replacement. i mean, i broke it - it was my fault, so not gonna even try the warranty route.
i guess that little shiny dome really is made of diamonds.
how did i break it? i gently laid the speaker face down on my carpet in order to access the back of the speaker. i hadnt noticed that the diamond tweeter sticks out about 1/2" past the speaker face. crushed. i'm sure there is some magically special reason for them sticking it out 1/2" but yeah, that design cost me $1270 today. frown.gif
and in case anyone was wondering, yes, you can tell a pretty big difference in the sound when it's broken.
post #11952 of 13894
You do not need new PREAMP, get new power amplifier. I suggest something in 400-500W range for 8 ohms. Make sure that it specified to work down to 2 ohms.
post #11953 of 13894
400-500 per channel? That's overkill for what I need I think
post #11954 of 13894
Is this a repair you can do yourself? (I also wondered if you could really hear a lot of sound quality difference with a broken diamond tweeter.)
post #11955 of 13894
what speaker will be fed with this "new" 500W amp? the PM1 only will get to 5Ω Hz of minimal impedance so You don't need a bigger amp. it is hard to belive but the preamp is one the major component in a stereo set up(I read that you only are setting a 2.1 set up) so I wondering why you chose a 9.2 preamp? if you really want that your new speaker sing, you have to give a good source and better preamp. my rotel RB1582 do not brought to my set up better sound but when I asked borrow to my dealer a high end preamp I could see a huge impruvement in sound, better midrage and deep bass output(obviously with the rotel amp)
post #11956 of 13894
sure, the repair is easy if a i have the new tweeter dome unit. the repair will take 2 minutes. the problem is the cost of the replacement part!!
and like i said, yeah, you can definitely hear a difference between the two speakers now. the one with the busted tweeter doesnt sound *horrible* - it's just very clearly missing some sound that the other speaker produces.
post #11957 of 13894
I purchased the 9.2 as i will use more channels in the future, just not needed now, and I can biamp with it now. It has very good components as well, it's no slouch, just not as good as I was expecting. What preamp did you go with?
post #11958 of 13894
For multichannel I will keep my denon that although is not good, it have a decent performance in this field, but for real listening music in two channel I will go with a classe CP800(I'm saving for it rolleyes.gif). have you the possibility to ask borrow a preamp? if so you could give a try. But one thing I'm sure you don't have a power problem.
post #11959 of 13894
Preamp should be as transparent as straight wire. I do not believe that 3311 in "pure direct" is not transparent enough. If you want to use bass management only feed it with digital signal. Almost all AVRs are piss poor in digitizing analog sources.
post #11960 of 13894
No upgrades needed if they already SUBJECTIVELY sound great to you. It would otherwise be a waste of money. wink.gif
post #11961 of 13894
Originally Posted by Rod#S View Post
Large for the 805D's, wow, that surprises me and I would be questioning the Audyssey system there. Some people don't run their 803's and 802's as low as 60hz. I would definitely bring that up to either 80, 100 or 120 for the 805's.
Don't question the audyssey system for this, It just reports back the results to the receiver/pre-pro. Its the brand that decides what todo with the results and how to set the crossover's and other results. You can change them (and should) without any effect on the audyssey results and settings. In this case 9 out of 10 you should move them to large if you have a good sub system.
Daniel.
post #11962 of 13894
Daniel.
READ THIS (WRITTEN BY CHRIS,ONE OF THE AUDYSSEY FOUNDERS)
http://www.audyssey.com/blog/2009/05/small-vs-large
post #11963 of 13894
"Best in the world" is very subjective at best. I love my 800 Series Diamonds (802's and HTM2) but definitely don't think they are the best. If I was rich I would be using speakers like Sonus Faber Aida's, Wilson Alexandria XLF's or Focal Grande Utopia III EM's. There is only one speaker that B&W makes above the 800 Diamond and that's the Nautilus but in that price range I think I would prefer Wilson Maxx speakers or for a bit less money Sonus Faber Stradivari, Wilson Alexia or Focal Maestro Utopia. Wilson, Sonus Faber and Focal are just three high end manufacturers producing amazig speakers but there are many more, those are just the three that have always had my interest.
post #11964 of 13894
Daniel.
If a sub is being used then you set them to small to engage the crossover otherwise setting to large doesn't apply a crossover.
post #11965 of 13894
I think you reach a point of diminishing returns with all this stuff. Are some of those "high end speakers" that much better than your 800 series diamonds? I'm not too sure I could hear the difference. Maybe you can, but for how much more $$?
For me, I feel very lucky to have my 804 diamonds. They are the best I have (and probably will) ever own. I'm glad to have them. (and they were a gift from my wife, too.)
post #11966 of 13894
Originally Posted by RSTide View Post
Well the 805Ds go down to 49Hz according to the specs, so I'm not overly shocked about the large designation. Audyssey has been pretty accurate for my previous speakers, but I agree it's being a little generous here.
Maybe I'll try 80 Hz crossover and see how that goes.
I have two 805N's and I can confirm that sometimes Audyssey XT32 does read these little guys as "Large" I can tell you the 805s (All series) are very affected by room placement. Regardess though, most EQ's show 60 Hz. My rear surrounds (Which are SMC1s) are also often read to crossover at 60Hz. Bottom line is the smallest 800 series speaker has a fairly good low end. Do they compete with my 803S's that handle L/R duty? Sort of, you don't get the same sensitivity for sure and therefore not the same potential maximum volume. OTH, the 805s really need to be fed with lots of power to get great performance. When I switched from internal power and played around with Emo XPA-1 monoblocks I was surprised how clear and loud the 805s can play. More than enough for any sane person in any normal size room.
All said and done, I'd cross over the 805s and SCM1s (I have) at 80Hz or 60Hz. I can't really sense any sub issues with going to 80Hz. 100Hz is too high.
post #11967 of 13894
Here is the measurement of the Stradivari:
http://www.stereophile.com/content/sonus-faber-stradivari-homage-loudspeaker-measurements
Objectively, it measures worse than the B&W 802D/ 800D2.
Here is the Wilson Maxx3:
http://www.stereophile.com/content/wilson-audio-specialties-maxx-series-3-loudspeaker-measurements
Objectively, it is one of the worst measured speakers I've ever seen - much worse than the 800/ 802. The Wilson's measure very poorly like Vienna Acoustics. The only speaker I've seen measured worse is the Zu Audio, which measures as bad as Bose. biggrin.gif
Here is the Focal Maestro Utopia III:
http://www.stereophile.com/content/focal-maestro-utopia-iii-loudspeaker-measurements
Objectively, it doesn't measure any better than the 800/ 802.
Objectively, the speakers that measure a lot better than the B&W include the KEF Reference 207/2, Revel Salon2, and TAD Reference1.
But subjectively, pure personal preference, it is anybody's call.
Edited by AcuDefTechGuy - 11/10/12 at 9:47am
post #11968 of 13894
Ok for movies crossing over makes sense, but for music unless organ music is all you play, I don't get it especially with B&W 800 Diamonds.
B&W recomendation is cross over at 30 or 40hz for movies and full range for music, I agree otherwise it might be best to just buy 805D all around and 4 subs. For a dedicated hometheater used only for movies that would be a great room.
To be honest when I put on a good SACD recording the 800 Diamond are extremely good
post #11969 of 13894
At a certain level, yes personal preferences and your ears are what matters. Who care how many reviews, just like there are movies that are total bust in the theater but have cult followers Brazil is one of them:D
On an other note http://www.abbeyroad.com/Studio/7/Studio-Three
http://www.abbeyroad.com/Studio/5/Studio-One
In all their rooms monitoring is provided by five B&W Nautilus 800D speakers.
I think they know something about music, you don't see KEF, Sonus Faber, Wilson, YG Acoustic, Magico, or any of the others there wink.gif They can buy what ever they want especially since they record s many movies, concerts, music...
http://www.abbeyroad.com/News/Article/264/The-Gramophone-Awards-2012
post #11970 of 13894
Yeah the numbers mean very little to me when it comes right down to it, it's what is heard that counts and for me looks also rank right up there. As popular as they are and as much great feedback as there is I'm not a fan of the Wilson Sophia or Sasha look. The mid/high frequency enclosure just doesn't do it cosmetically for me. What is done on the Maxx, Alexandria and to a lesser degree the new Alexia I do like though. Cosmetically the Stradivari and Elipsa look really nice as do the Amati anniversario and Aida. I like the Ultima Salon and Focal Maestro, Stella and Grande Utopia looks as well.
Cosmetically for me my choice of speaker in the 20kish to 30kish range is the 800D2 (over say the Sasha, Elipsa SE and Ultima Salon) and in the 10kish to 20kish range I like the 802D2 (over say the Studio Salon, Elipsa, Sophia, Cremona M). I would love to have an opportunity to hear all of these speakers but alas that will never happen. My dealer sells Focal but doesn't have the Utopia series on hand. Having now owned my 802's for about a year and a half I would love to be able to get a comparison of the Scala and Maestro towers.
  Back to Forum: Speakers
