Originally Posted by MUDCAT45
The best bang for the buck is the Sony STR-DN1030. It can be had for $450. For those who will scoff, try it first.
Originally Posted by raycie
Getting a huge bug to get a pair of CM1s to start off my system. System would be an all-in-one, music and movies. Starting off with a 2.1 then possibly expanding in the future. Sub will be something in the REL line. I need the ability to have AM/FM radio, and possibly hook up all my components (DVD, Wii, AppleTV) so they can be played from the speakers.
Looking at integrated amps, HT amps, etc. With an integrated, I would need a tuner and other components. With a HT amp/receiver, they would be an all-in-one.
Amp/Receiver options:
NAD T748 (average $700)
Yamaha HTR-4065 ($270 Costco)
Marantz (need to stay in the $500-700 range preferably)
NAD integrated (but would need separate components to complete. Unsure how I would integrate DVD/Wii, AppleTV)
I am by no means an audiophile, but I could hear and distinguish the difference between the CM1 and the 600-series. Amps can be upgraded in the future, but did want to spend good hard earned $$ on quality speakers (hence the CM1s). Would love to spend no more than $2,500 to start. CM1=$1,000 / REL = $600-800 / Speaker Stands = $200 / Amp = $500-$700..
Question:
1. If I go the cheap and easy (good enough for now) Yamaha from Costco is that enough power for the CM1s even in 2.1 mode?
2. NAD HT or integrated
3. Marantz, Denon, Onyko - Which one bang for the buck???
THANKS!!!..
Question:
THANKS!!!..
I wouldn't touch SONY anything for audio. The choice should between Onkyo and Denon. Try to find independent reviews with test bench measurements. Get one that measured best.
