Originally Posted by fatuglyguy
^^^^^^^ I would definitely suggest getting the stands if you're going to buy the CM5. When I had originally purchased my 685 I had them on a shelf. I eventually got the B&W metal stands and they sounded significantly better on them.
Perhaps you don't need the B&W brand stands, but I think for how well they're constructed, $150 is not bad at all.
yea.. I will start off with the stands.. the $150 stands.. not the $400 stands.. If I was buy the $400 stands then I could just go with the CM8s..
Can't wit to get my 3.1 setup!!
