AVS › AVS Forum › Audio › Speakers › B&W Owner's Thread
B&W Owner's Thread - Page 414
post #12391 of 13875
Originally Posted by BVLDARI View Post
Where do you have the 802D2 crossed over? Thanks.
Here are some opinions on your latest posts with a few facts to throw out first.
1). I do not own either D's or D2's (as they appear to be called now).
2). I have a desire, but not yet the fortitude to pony up for any Diamond Series.
So, more opinion based on my lower experience, decent room, and equipment.
You have a tough question. I am a huge proponent of the biggest baddest center you can get. OTOH, if you are a movie watching guy, nothing beats a pair (or more) of quality subwoofers. Your Left and Right are, IMHO, two of the best speakers ever made. For stereo music, I could not imagine not letting them run full range (well except for all the discussion about Audyysey needing to be set at small - no one is forcing you tooo though). Also, not much music has content even close to as low as they can play. Movies though have content that really should be played by a dedicated subwoofer.
First answer then, I'd use a crossover frequency of 60Hz. If you use 80Hz, I don't think you will be able to even tell any difference but 60Hz seems a better choice with your large L/R's. I have experimented a lot with this with my very inadequate (whimpy, whimpy, whimpy wink.gif ) 803S's. I could not tell any difference during many blast-o-tron type movie content sessions.
As per the center. Golden eared pros will tell you it is best to timbre match the fronts as tightly as you can. I do not disagree with this but I would add a few reasons to save a couple bucks and locate the original D center. 1). If you use a good EQ capable Pre or AVR, the EQ process will help get these different tweeters to sound more alike. 2). I too would prefer the newest D2's but is the tweeter $2K or more better? 3). Although I believe the center is critical, I could argue that there is less high frequency content in most movies going to the center. If the movie soundtrack is edited like most, you will recognize that more of the music type content does play to the L/R channel. One example of this is "Marley and Me". Most of the movie is just dialogue and then every once in a while the movie super imposes music, which is all directed to the L/R and also the surrounds. This is not a well made movie as far as audio goes but is quite typical to many movies. So, to me the center should match or come close to matching the mids and treble, especially balanced across different volume levels; more so than an exact timbre match at the highest frequency. (Those who disagree, let the public bashing begin. It's OK as this opinion might be a bitcontroversial.In the case of my room, my center just is not a perfect mid and bass matched speaker. The drivers are different and they are mis matched as to port no port. Now the trebles, to my middle aged ears do match. Just my personall gripe on my center.
Having great subwoofers to me, is a must. Two is probably my highest recommendation 4 even better (Note, I do not have 4 - preparing to experiment with 3 in a 2+1 dual EQ system). I know I have posted that the center is da thing; but for movies two subs properly placed and EQ'd is da bomb.
For $2K, you could approach getting two Rythmik subs (Personally I think they are pretty unattractive but boy do movie guys rave about what they can do). You could get 2/3rd of a JL Fathom. This manufacturer can't stop winning awards. Two Hsu's or SVS's. The list is pretty long.
Your other comment about the port and distance from the wall. I would imagine 1 to 3 freet. 1 being on the short side. Truthfully, I blew it on this as I had never looked at the HTM2D and D2 as to look would get me wanting - I didn't even recognize they were ported; jaelous, I am now. . Wanting begets buying. Buying creates conversations of a somewhat negative bend with my better half. It's a slippery slope.
Only an opinion then, if you will be watching a lot of movie content and want a set up capable of really playing loud and low; I would recommend getting the D center and spending more on subs. This is not one of those definite opinions though as how you like to listen, what you listen to, and how much you really, really want a total front matching speaker set means to you. Nice problem though and good luck.
post #12392 of 13875
How many pages are going to be dedicated to the "speaker break in" thing???? either it happens or it doesn't....if sound changes after a certain amount of time then it will, if it doesn't then it will not ...... either way you all are going to play your speakers longer than any of the mentioned time limit. let it go already.
Bill
post #12393 of 13875
Have matched CM9 with peachtree 220 amplifier. Had friends over and played some loud music for dancing. Also attached iphone to the (aux) novapre and the music wasnt that great sounding. I suspect highly compressed audio. It did go in and out a few time as we were playing it loud.
Question is can playing CM9 loud damage the speakers in any way. Any experience with playing this speaker loud. Also can peachtree 220 damage the speaker.
post #12394 of 13875
your problem is that you were playing it using auxiliary and not using the novapre as the dac. ALWAYS let the nova do the DAC jobs
http://www.amazon.com/Apple-TV-MD199LL-NEWEST-VERSION/dp/B007I5JT4S/ref=sr_1_1?ie=UTF8&qid=1355710057&sr=8-1&keywords=apple+tv
This is what you want. Also did the homework for you and if you want spotify then try this but it also explains how to get itunes
BTW you have a really nice setup.
This is what i got
"Apple TV. AirPlay is Apple's method of sending audio or video to another device. First, you want to go into the Settings on your AppleTV, and ensure AirPlay is enabled. Then, on your iPhone, ensire it is connected to the same wireless netwotk your AppleTV is on. Then, go into Spotify and play some music. Once the music starts playing from your phone, double tap the home button on your phone, and once the mutitasking bar comes up on the bottom, swipe once to the right. To the right of the music controls, you should see a button that looks similar to this:"
That part got cut off but it's there should only be one button
post #12395 of 13875
This is what i got
bthrb4u thanks for your response. I do have appleTV enabled. HOwever it would have been a hassle to get this going in the night so we were just plugging them in.
Btw do you think peachtree 200 can damage CM9 speakers.
post #12396 of 13875
saw Class'e and turned around.$$$$$$$$$$$$$$
post #12397 of 13875
Quick question... Cm5s and cmc2 coming in soon. What is the consensus in connecting speaker wire? Banana plus? Receiver is a marantz 5007
post #12398 of 13875
I don't think there is a consensus on hooking up your speakers. Some purists like simple wire, others enjoy a complex high contact connection. I am a fan of Banana Plugs. They are easy to use, look decent and I can't tell any difference between raw wire and Banana Plugs. Just me though....
post #12399 of 13875
Edited by ratloko - 12/18/12 at 11:06pm
post #12400 of 13875
s
post #12401 of 13875
This kind of tracks with what I did for the front 802D2 - I have them crossed over at 40Hz because I want the 802D2 to produce more of the sound vs. blending with the sub. I will upgrade my sub in the future, and question if at that point I will end up going to 80Hz all around or if I will stay the same... Which brings me to my original question, if I cross things over at 80Hz is it worth to spend (retail money) $5k for the HTM2D2 vs. say $7k for am HTM4D2 and a DB1? Or am I better off to spend the $5k on the center, and maybe cross it over at 60Hz or whatever and use less of the sub.
Also, this reminds me of a different question, being that the HTM2D2 is ported in the rear, how/where do you have it mounted?
I would XO @ 80Hz and get a single 805D2 (or HTM4D2 if limited space) + dual Funk 18.0 unpowered subs ($4K total).
post #12402 of 13875
Finally going to setup my CM9s in my dedicated theater room - wondering if I should use the spikes or not? This would be on a carpeted stage that is filled with sand.
post #12403 of 13875
I put mine on the plinths. I wanted the stability for when the wife cleans or if the cats decide to fight in the room. It may compromise the sound some, but peace of mind is worth it biggrin.gif
post #12404 of 13875
Yeah, I prefer bananas over bare wires and spades also.
post #12405 of 13875
Hello all:
I've got a DM640 pair with one of the 2 200mm bass drivers damaged - it's making a horrible racket. It appears due to age that B&W no longer carry this component and I'm wondering if any of you have recommendations for either a good website, a reputable bare driver brand or perhaps an equivalent 200mm (8 inch) B&W model from another line that would work.
Thanks Much
post #12406 of 13875
hey folks, does anyone know what size bolts are used on the SCMS wall mount? I am missing one that goes into the speaker.
post #12407 of 13875
PM1s vs CM9s...strictly for stereo. Which one would you go with? I have a long narrow room (27x12x8) and listen to a variety of music from alternative rock to jazz to acoustic music. I have Rotel amplification so power won't be a problem. The CM9s are on display at my dealer but no PM1. If I go with PM1, I'd def. partner them with a good sub. Just wondering how the PM1 stacks up.
post #12408 of 13875
I have no opinion about PM1, however I have CM9 (with Yamaha RX-A2010). CM9 in my opinion have some problem with trebles, especially cymbals, rather withdrawn. In acoustic music it is fine, because in some speakers cymbals were too exposed. But in rock/metal music they are too withdrawn. Other than that excellent sound, wonderful basses, a lot of energy. When demoing CM9 take it into account.
post #12409 of 13875
Hello all, new member here. Apologies if this is in the wrong section. Does B&W still make center channel stands? I'm in the midst of a upgrade and would like to upgrade to the CM Center 2. I can't think of a practical way to incorporate one into my existing AV furniture so i'm leaning towards a center channel stand/wall mount. Thanks!
post #12410 of 13875
60Hz. I've tried 80 Hz and 60 Hz. I like 60 Hz better.
In regard to setting crossovers, I start with what Audyssey recommends, then spend many hours listening to lots of music and movies. Once I get a feel for the system sound, I make small changes to the system settings until the sound is what I want.
Everyone has a different room, different speaker setup, different electronics, etc. My recommendation is to listen, try settings, then enjoy.
In regard to "what speakers should I buy?" I just spent time thinking about what I wanted. I started by adding the HTM2D2 to an existing set of speakers. At the time, my system was comprised of speakers made by a variety of companies. (These were just speakers I had purchased over the years.) The HTM2D2 made a great improvement in sound. This change was so impressive, I decided to buy a pair of 802D2 for fronts. A little later, I decided to add the 805D2 as height. I still use a variety of speakers for surrounds, rears, wides. Some day, I would like to have all my speakers be 800-series. For now, the sound is pretty good!!!
post #12411 of 13875
I am picking up an htm1d in the new year to replace my htm2d. Which I have for sale. But I may keep it as a front height.
Any ideas of how hang such a beast from the ceiling. The htm2d that is, I would never try to hang a 98kg centre from the ceiling. Lol
post #12412 of 13875
I have the following 7.1 setup:
Marantz 5006
685 front
Htm62 center
686 surround
Hsu sub
I have limited room and I want to make it a 7.1 , would it work if I add the m1s as the rear 2 ? I'm thinking about placing it high up on wall behind the couch (there really is no room for another pair of 686s due to size limitations of the room)
post #12413 of 13875
@raycie, please post once you have your setup, eager to hear your thoughts, i am considering a similar move.
Good luck mate!
post #12414 of 13875
B& W makes ONE center speaker stand that I am aware of. Most authorized B&W dealers will charge the list price of $499.00 for it. I recently purchased this stand, dispite having many reservations because of the ridiculous price. However, I must admit it works very well with my HTM2D center speaker and makes it look very nice.
For a CMC2, I would probably seek out other more reasonably priced center channel stands from other manufacturers. Stands & Mounts.com has many units to check out as well as many other sources.
Edited by SugarmillMan - 12/21/12 at 3:56pm
post #12415 of 13875
Looks like they used to make one but no longer do. I'm leaning towards a Sound Anchors solution that will take my flat screen and center. Anybody have experiences with their products?
post #12416 of 13875
Got it all setup. Love it. Watched the avengers tonight on bluray, and wow, no regrets at all. I could very well live with a 3.1 for awhile. Music is awesome..
Some thoughts...
1. Very very glad i made the move to the cmc2 over the cmc. That thing is expensive, but no doubt worth the money over the cmc.
2. Also very glad i pushed for the cm5s over the cm1s. Haven't pushed it too loud yet, but even the wife noticed how good they sound.
3. I may wonder about not getting the cm9s instead of the cm5s, but for an extra $1,500, i could justify doing what i did ( for awhile)
4. Already thinking what I'm going to do if i ever do want to do a 5.1. I could get a pair of cm8/cm9s for the front, and move the cm5s to the rear, but that would definitely be over kill to have cm5s for just surrounds ( for my room). I could also do either cm1s, or m-1s for the rear. Or like i said earlier, the setup i currently have is way more than i started with, and could keep me happy for a long time. ( or until i have more money i can throw at some cm9s...lol)
5. To think that i started this whole journey looking very intently at a $700 bose 6 system from costco (with amp). Wife was a little shocked whem i gave her the final bill for this build, including a $200 level 2 surge protector..lol..
Final setup:
Cmc2
Cm5s ( on cheaper B&W stands filled with sand)
REL T5
Marantz 5007
Edited by raycie - 12/22/12 at 1:18am
post #12417 of 13875
Congrats! CM5s as surrounds with CM9 fronts would be excellent for multichannel music.
post #12418 of 13875
Congrats Raycie! How long have you had them hooked up? Can't wait to get my setup, basically just being a wannabe for now lol. $
post #12419 of 13875
Got the speakers on Thursday morning. Been listening or watching a bunch as I am on vacation.
The multi-stereo baffles me a bit. Currently I have my marantz on the auto setting. When listening to pandora then only the left and right play with the sub. When playing a movie, then the center kicks in as well. If I put the marantz on multi-stereo with pandora, the center kicks in for some of the instruments.
Should I be listening in multi-stereofor everything?? Is it just preference? I have to test it, but when I play a movie, is the multi-channel stereo setting good, or will I need to switch?
If I ever do get some rears, or new fronts, will multi-channel play music through all speakers?
http://i1293.photobucket.com/albums/b593/808raycie/IMG_20121221_111716.jpg
post #12420 of 13875
What you have described sounds correct. On auto multi-channel sources should be multi-channel and stereo sources should be in stereo. Some people like to simulate multi-channel for stereo sources but I'm not a big fan. Congrats on the new setup. I'm sure it sounds fantastic.
  Back to Forum: Speakers
