AVS › AVS Forum › Audio › Speakers › B&W Owner's Thread
B&W Owner's Thread - Page 88
post #2611 of 14077
xxdimuxx, I sent you a PM on the Klipsch forum.
post #2612 of 14077
If you are using Rockets (as I do believe you said elsewhere), then yes, you would probably find the B&Ws to be comparatively (and very generally) bright.
Penngray, I wouldn't call the B&W bright but I won't hear them the same way you do.
I do own the following Rocket RS450s, Ref .5s, Klipsch RB-81s, Paradigm Studio 20s.
I use the Rockets the most so I guess that is my reference point, thanks for the opinion. I just didnt know what the B&Ws should sound like.
post #2613 of 14077
I currently have a Denon 4308ci and 7 speaker Klipsch Synergy speakers the SB-2 for mains the SC-1 for center the S-1 for side surrounds and the newer B-2 for back surrounds with a home built 10in kicker subwoofer won from a car stereo show.
I am looking to get newer and better speakers than what ive got and i was looking at the BW 683 for mains, the HTM-61 for center the DS3 for side surrounds and the 686 for back surrounds, plus i have the MFW-15 on order
what do you think of this set?
post #2614 of 14077
Anybody know where I can pick up a couple of extra speaker grilles for B&W CWM 650 in-wall speakers?
post #2615 of 14077
I just scored some mint used 603 s3s on craigslist for $450 SUUUWWWEEET
post #2616 of 14077
Originally Posted by TJHUB View Post
I hear you. When the family is around, I usually keep to my jazz or pop music for my daughter (she's the other music freak in the family ). But when I'm alone (not very often), I play my car music which usually consists of Nine Inch Nails, Tool, Korn, etc.
I am a tweaker, but it can get old. I'll move my speakers and listen to them for a few hours or even days. I've just given you what has worked for me. I've never used any room correction, but I would try it if my pre-pro had it. I am EXTREMELY happy with my 805S's. They are VERY good at playing everything I throw at them. Best purchase I've made audio wise is a long time. Too bad they are so expensive, because that part hurt a little.
One thing I'd like to quickly mention is that I wasn't all that happy with the way my sub was sounding and how it was blending with my 805S's. Just this week I picked up a Behringer Feedback Destroyer and EQ'd my sub. The results are nothing short of astounding! The blend between my sub (SVS 20-39PC+) and my speakers is perfect. The sub is completely transparent; the bass is very balanced and articulate and sounds like it's coming from my little 805S's. I can't believe I waited this long to EQ my sub.
Funny, but that is the same for me, home alone = Tool session.
I've read a little about the Behringer and honestly it just sounds really complicated. Not a huge cost impediment but I am pretty new to tweaking a system AND owning a sub so I am having a tough time even knowing what good bass is supposed to sound like. I will keep looking into it though but I'm not in a dire need to blend my sub with my mains as the 683's are pretty competent with bass.
post #2617 of 14077
Originally Posted by remodeler View Post
I still like my Rock and Heavy Metal, I just also listen to more Electronic, Funk, even some Rap. And when the wife is around we listen to 80's pop. I've always liked classical but it doesn't have much impact on a mediocre system. Now I find I listen to more and more, although I still like the really dynamic stuff. If your familiar with O' Fortuna that rocks on a good system.
Not familiar with O' Fortuna - will check them out on Allmusic.
post #2618 of 14077
Sounds like that will rock (quite literally depending on you ft3 ).
post #2619 of 14077
Congrats! My dealer has a "demo" pair for $750.00 in the store. I was at one time VERY temped to pick them up.
post #2620 of 14077
Future upgrade question:
Thinking about getting the most out of my 683's, I was considering an external amp. What are your guys thoughts on this?
The 83's don't seem (but then again what do I know) overly hard to drive and I generally don't listen really loud (-15 master volume top end) but I do want to get the cleanest sound out of the speakers. So would a quality amp be overkill or just the thing to really take the experience to the next level?
I am currently driving the speakers with a Marantz 7001 that will probably be around for a while.
Thx again in advance.
Also, what constitutes a quality amp. Was originally thinking Rotel, but the new Emotiva caught my eye. That said I've heard a lot about the other companies but my budget will never be in the McIntosh range even for used stuff.
post #2621 of 14077
My honest advice would be to not to bother. If you are not listening at very high volumes, then it's unlikely you'll find a noticeable difference in the sound by upgrading just the amp. A high quality amp can improve the dynamics of a speaker which often translates to cleaner, more detailed sound, but that's assuming your old amp was in some way straining.
I think you'd be better off spending money on stuff like a SMS-1 to improve the quality bass on a subwoofer, or possibly some room treatments with the help of a professional to get the best out of your current speakers.
post #2622 of 14077
To be honest, I was VERY intimidated at first. REW looked complicated and reading through the guides just made things worse. The guys on hometheatershack weren't answering questions at a noob level either. However, after going through the process, I can tell you it was very simple. The software is great. It's just small details you need to understand and it couldn't be much easier. I'm am a fairly advanced computer guy, but I didn't really need to draw upon any real skill.
The guys on the forums at hometheatershack are just super. They repeatedly answer the same stupid questions from new members every day without giving any attitude. It's VERY nice! Bruce and Wayne are very helpful and straight to the point. Trust me, it's easy. I never touched any of it until last Wednesday night. It took me all of maybe 2 hours and I was done.
The BFD itself couldn't be easier to use either. There is no way anyone could justify to me the need for midi communication from the software to the BFD for settings. REW tells you exactly what parameters to enter and it takes about 15 seconds to enter a filter. I use a total of 5 filters on my BFD.
I can't stress enough how anyone with a sub that doesn't already own some sort of room correction for their subs should be getting a BFD and using REW. The improvement is HUGE! Getting my sub to blend better with my B&W bookshelf speakers is one of the best things I've done for my setup. The best thing is that it's so cheap.
My friend's new BFD is arriving today. He too has B&W 805S's for mains with an SVS sub. I took my laptop and REW setup to his house this past Monday, and within 10 minutes I showed him what he already knew. He *needed* a BFD. We're getting together tomorrow at lunch to get everything tuned in. Should take all of 15 minutes.
Here are my results:
Before:
After:
One thing I'd like to note is that for the first graph I used an 80Hz test tone to set my sub's gain. I needed no low spots for the REW software to work properly and I already knew I had severe low end room gain.
Sound wise, my 805S's lacked that punchy midbass with or without my sub. Now I have that punchy midbass. What's strange is how strong my 805S's could play a 40Hz test tone. They were weak around 50Hz to 70Hz, but at 40Hz they will play at reference level when not high-passed. I also installed the port plugs to keep them from messing with my near flawless sub frequency response.
To sum up: GET A BFD!!!!
post #2623 of 14077
D-strasse, you've heard the song I'm sure it's a classical piece from around 1900. Extremely dynamic. It's currently being played on an NBA playoffs commercial. Been in numerous movies and such.
As to the question of an amp, I bought an Adcom to drive some older B&W that are really not sensitive and it made a huge difference. I hooked it up to a set of Klipsch Forte the I bought and it's just amazing what it does for the sound. I'm a believer in amps now.
TJhubb, yeah I couldn't pass the deal up. I was just perusing Craigslist and saw an ad for them. I'm going to Ebay them and make a few bucks. They are nice and sound excellent but I really don't need any more speakers. I only have one set up but I have 5 sets of mains at this point.
post #2624 of 14077
Ok I missed the not listening loud part. If you don't listen at high levels then I'd say Warp is spot on. I like to feel it, so I crank it up. The receiver just doesn't have the balls and it becomes a little muddied at higher volume. At low volume you just won't hear it. At high volume it's grating to the ears.
post #2625 of 14077
Very nice! I sold mine for $800.00 when I upgraded to 703s, but that was before the new 600 series was launched.
post #2626 of 14077
TJHUB,
Just so I'm clear, I don't need a midi connection on my laptop? I was perusing the REW/Behringer threads on HTShack and it sounded like I needed one - and that's where I bailed out
I think my sound card might not be up to snuff but I do own a RS SPL meter. Is this enough?
And as much as I'd love an SMS-1, there just isn't the cash for that right now.
Thanks again.
post #2627 of 14077
It's German, not Irish!
O Fortuna! is the opening of Orff's Carmina Burana, written in 1935/6. It is the numbingly repetitive choice of ignorant music programmers for sports events and early coming-attractions clips.
See: http://en.wikipedia.org/wiki/Carmina_Burana_%28Orff%29
post #2628 of 14077
Oh my God! I used an apostrophe when I shouldn't have. Let us call the punctuation police and I will throw myself on the mercy of the courts.
It is used way too much but in it's entirety it is a wonderful song. I really have no care at all for the history of songs as evidenced by my limited knowledge of such things. I just know when I like something or not.
post #2629 of 14077
Just once, I would love to hear this chorus played at a sushi bar.
O, for tuna!!!
post #2630 of 14077
Just for the record, you did it again.
post #2631 of 14077
Actually if you want to get technical it's entirety is correct I believe. I'm sure there will be others that disagree.(or should that be other's)
post #2632 of 14077
It was a joke.
post #2633 of 14077
Now I'm just not sure.
One thing I am certain about; this thread is WAY OFF TOPIC.
post #2634 of 14077
Kal, so was the response. See the little smiley guy? And yes way off.
post #2635 of 14077
It's not correct.
post #2636 of 14077
Originally Posted by EJ1 View Post
It's not correct.
Thats' right, it aint''
post #2637 of 14077
Hi all...Have Nad c-352 with 704 speakers (and love it...). Using now standart cables. Any suggestions for cables? Thougt of QED X-Tube 300 or vdh cs-122 for example..opinions about interconnect r welcom also..
post #2638 of 14077
Yes, I am wrong. I've done that for a long time. Well, you learn something new every day if your not careful.
post #2639 of 14077
I have 704's (and I love them, too, now that I am using them with a sub). You can use ordinary 12-gauge lamp cord from Home Depot or your local hardware store. There is no reason to buy expensive speaker cables. (I will now go into my fallout shelter and wait for the bombs to start falling. There are rabid disagreements about cable-related issues on every audio-related internet forum.)
post #2640 of 14077
I am interested in purchasing a pair of 802Ds, can someone recommend a good dealer with good pricing (I have no dealers within 350miles....)? Please send me a PM!
  Back to Forum: Speakers
