AVS › AVS Forum › Audio › Speakers › B&W Owner's Thread
B&W Owner's Thread - Page 96
post #2851 of 13900
Originally Posted by rat123 View Post
WonHung,
What stands are you using for the 804S? Did they improve the sound?
Hi,
The speakers are the older Nautilus 804s. But the stands will also work with the 804S speakers. The stands are from Sound Anchors in Florida. I have the taller floor stands up front and the standard height stands for the rears. They only sell the standard height stands now as a standard stock item. But you can ask them to custom make any height stand you want. These things are solid and have a lot of weight behind them.
As far as improvements to sound quality, I can't really comment. I bought my first pair of N804s used which had the tall Sound Anchor stands included with them. I've used them that way ever since I got them. I added the rear Sound Anchor stands more for increased stability than for any real sound improvements after a couple of....ahem....accidents with people visiting. With the stands, the speakers are definitely more stable and tipping them is a bit tougher.
post #2852 of 13900
Wow, that is really going to be something. Are you going to go with the unfinished "mules" or purty them up first?
i'm gonna use bedliner as my finish...I'm not doing veneer this time. Will look like this finish:
alternatively, I may just go with a coarser bedliner finish..requires less coats, and it's cheaper
post #2853 of 13900
Original Post by ADM (I neglected to click the include reply option
I see that you have the DS3s. How do you like them? Also where are they deployed in terms of your seating and the walls?
Currently, my set up is:
Front: B&W 604-3s
Center B&W LCR600
Surround: Hsu STF-3
Rears: Lafayette -Criterion 50 (40 year old 3-way on floor in each corner)
Harman/Karman 7200 AVR
Considering adding the the DS3s to either replace the current rears or conceivably having both with the DS3s raised in the corners above the 50s.
Unfortunately due to my having doorways on the rear wall at the point/adjacent to the 50s, the only option for the DS3s are above the entrances.
...Mark
Sorry for the delayed post. I have been very pleased with my surrounds. At first I was a little unsure since the sound coming out of them was not very obvious, but then I realized that that was the point. From the attached images, you can see that the builder did me no favors on the placement (too high and too far into the corner), but the speakers do their job very well. Anyone building a house in Dallas (or looking for a recommendation of who to use, or NOT use, send me a private message and I'll share my perspectives). I eventually hooked up with a knowledgable, skilled, and ethical individual and the story ended very happily. I initially ran the DS3's with the LCR600 and 602.5's, and they matched very well.Attachment 113254
Attachment 113255
Attachment 113256
post #2854 of 13900
Originally Posted by Aphasia View Post
Even on rather low volume i get a pretty bit of excursion on that particular sequence. It is exactly at 3rd chapter, at 9:42 to ~9:59. Get a peak at the beginning and at the end. I get about as much extension at the scene in the end though but with shorter times of excursion.
What version do you have. My version is the PAL-version with region 2 and 5. Im thinking that it may be either of these things...
I may have some kind of of "weak spot" with regards to a resonant frequency for the sub, because i had a hard time getting the exact moment if i didnt play a few seconds in advance, but it might be that i just missed it being tired.
Or it is that the movie is just mixed at that much of a higher level. It has decent LFE output throughout the movie, but it also has some extremes. But what i gather when i sit and just watch it and take the overall volume into account, i need to have the volume at least 6 db lower and perhaps 10db lower then say, Transformers or comparable action movie for the same sound output. The next time i view a movie and its not in the middle of the night i might take a look exactly how much difference there is.
Actually, I am not sure which version I have...I don't seem to have any letters or numbers the match what you describe, so that would be a difference. Where on the DVD should I look for that?
At first the 683's seemed too heavy in the bass, but not anymore. So either there is a big difference after the break-in period or my ears are getting used to the new sound...maybe I have just been lucky with the DVD's and Blu-Ray's that have been arriving in the mail lately. Regardless, even if my ears are confused, my eyes can still see that there is not a lot of movement.
post #2855 of 13900
Originally Posted by WonHung View Post
Reid_T,
I've considered the acoustically transparent screen but didn't want to chance the potential issues with having one set up. Plus I didn't want to have to have both a plasma and a projector as the room is meant to be a general purpose room. I like the fact that I can kick back in the morning natural light which spills into the room. Although the lighting in the room isn't very bright during these times, I can see it impacting projector performance.
As I've said before, to me a 50" screen is good enough. The picture does distort the size of the plasma in relation to the rest of the room. It's really not that bad.
WestCoastD,
Thank you for the compliment.
Your absolutely right...and a genius to boot. You should never underestimate the beauty of natural light, but what do you do at night when the sun goes down? I guess that means that we all need TWO rooms?! One like yours for day time viewing, and another, more theater centric, with screen, projector, etc.
You think our wives would mind?
post #2856 of 13900
Originally Posted by btf1980 View Post
Took some shots of my CM series.
CM7 x 2
CMC
CM1 x 2
PV1 sub
Driven by Rotel RMB-1075 and Rotel RSP-1069
Man, I stink at taking pics....
I would love to see a photo of these famous bungs that go into the ports at the back of the CM7s, could you upload a pic.
JG
post #2857 of 13900
Hi,
I ordered a pair of B&Ws 804S and the HTM3S center about 2 weeks ago, along with the Sound Anchor stands for the 804S and their SDACC center stand. Everything was delivered to the dealer 10 days ago, but the center SDACC stand was delayed and should be there this week.
I haven't seen any comments regarding the adjustable SDACC stand, so I hope it works well.
post #2858 of 13900
Attachment 113255
Attachment 113256
Wow, those look about 12-15" higher than they should be, but as long as they sound OK. Are you using them in bi-pole or mono-pole mode?
post #2859 of 13900
Hi All
My system is as follows:
Amplifier: Yamaha RX-V3800
Front: 683
Centre: HTM61
RearS3
Sub: ASW610
My problem is that the sub does not come out of standby mode and I have to leave it on permanently. I have set my front speakers to large with a crossover frequency on the amp set at 120.
Is there anything I can do to rectify the problem
The system works perfectly once the sub is on.
Rgds
post #2860 of 13900
Hello fellow B&Wer's. I purchased a new setup about this time last year and I have really enjoyed it. I am about 60% HT and 40% music content wise. I am looking to upgrade from 5.1 to 7.1 soon and would like to solicit some opinions as far as which speakers I should go with for the surround back channels. My room is medium sized, I suppose. It measures 16' wide by 20' long. I have attached a crude MS Paint overhead view of how my listening area is set up. My system components are as follows:
Cambridge Azur 640R Receiver
AudioQuest Interconnects and Type-8 speaker wire
B&W 683s
B&W HTM62
B&W DS3s
Paradigm Siesmic 12
Belkin PF60 Power Console
PS3 for Blu Ray playback
Cambridge 840C
Samsung HL-S6187w HDTV
There are a few other various pieces, but those are the most important ones for my purposes here.
What would the best matching set of surround back right/left speakers be? I have considered another pair of DS3s but I am unsure as to whether or not the dipole dispursement is necessary or the difference in cost is even necessary over a pair of 685s or 686s. I would prefer to wall mount them on the rear wall at or around the same height at my side surround DS3s which are about 4 inches from the ceiling (8' ceiling). Recommendations? Thanks in advance.
post #2861 of 13900
i have the 686s they work and sound great, i would say for the amount of material that goes threw those extra 2 rears you should just go with the cheaper 685 or 686. Remember that you can turn off dipole via the switch on those DS3s. You can also wall mount the 686s and prob the 685s too, they have a bracket on them, i use mine on stands.
post #2862 of 13900
Thanks for the prompt response. I do realize that the DS3s can be placed into monopole mode, and as they are a great wall mount solution, they unfortunately weigh in at almost double the cost. I was really leaning towards the larger 685s largely for 2 reasons. Both the 685s and smaller 686s are ported, but the 686s are ported in the rear (685s are ported in the front) which would leave less room for mounting purposes as well as the fact that it would increase potential reflections from the rear of the speaker. The 685s have larger mid/bass drivers (6.5" versus 5") so it can handle more content. Some of the DTS 7.1 MA discrete content does get fairly demanding of them from time to time - I have listened to some 7.1 setups to see if I would be interested in it for my own HT. Do you have any pictures of the brackets? I would be delighted to have a wall mounted solution over a speaker stand for rear image consistency as well as room demands (there is a closet door in the left rear of the room). Thanks for your reply!
post #2863 of 13900
Yep, they're at least 12" - 15" too high. I've tried it both ways in the past, and will undoubtedly try it both ways again in the future, but for now the more difuse sound of bi-pole seems to work a little better. Of course they might sound even better properly placed, but at some point you have to stop fiddling and start listening.
post #2864 of 13900
As you can see from the images in my post, mine are too far into the corner. Generally, it isn't an issue and sound moves seamlessly from front to back, but there times (Band of Brothers - Day of Days) where the sound is obviously in the upper corners of the room and not just behind us somewhere. Based on your diagram of a rectangular listening position, I would think that placing the rears just inside the extreme left and right of the listening position would be the place to start. Then follow the advice of your ears from there.
post #2865 of 13900
You might try the two side surrounds in bi-pole mode and the two read surrounds in mono-pole. I've read people get a nice sound with it setup that way.
post #2866 of 13900
you can sort of see the bracket in this picture, i wouldnt see why they would be any different for the 685s
post #2867 of 13900
I see a red x
EDIT: Nevermind, work computer blocked it since the link was from facebook. Looked at it on my iPhone and the picture loaded fine.
Thanks for posting that. Does the bracket allow for the speakers to be aimed in any way?
post #2868 of 13900
its working for me, check your browser settings, are images being blocked?, refresh?, is anyone else seeing an x?
post #2869 of 13900
I can see it, and I am over here in Ireland!
JG
post #2870 of 13900
no its more like a heavy duty picture hanger
post #2871 of 13900
JG
I sent you a pm.
post #2872 of 13900
Hello Guys & Jake
Sorry it took me a while just got My first ever speakers 685 for main front with a Marantz SR7002 ,Monster HTS2600, bought them like 2 months ago & haven't stop talking about then till now next week Going to buy Velodyne DD12 for sub & then OFCOURSE B&W CENTER thinking about the HTM61 any ideas(since you cant go wrong with any B&W in my opinion)in the future moving the 685's as Rears & have to buy towers but have No Idea which pair 700's, 800's ,or last high 600's model KUDOS FOR THE THREAD father (rest in piece)& sister are musicians so Sound quality are most important HT 43% Music 47% gaming 10% .
For all the "bashers" of B&W i haven't even looked there way & even known the excited to my def ears (lol). right now only in a 1 bedroom Apt. with my wife & the neighbors come & ask my to lower the volume from -13 to -20 only from the pair bookshelf's -WOW ... can't wait to move to a small house god willing & have a dedicated room for my ""toys"
All the best & waiting to hear reply's for my next purchase ... ?
post #2873 of 13900
Originally Posted by Jake Sm View Post
I noticed that I hadn't seen B&W OWNER'S thread , but that there are a lot of owners on this forum and I think that the consistant bashing from about 4 posters makes people hesitant to get involved in any of the many threads that keep getting nasty. So, to that end, I think that if there was a thread where the Lovefest could be conducted without bothering NON-owners and the bashers weren't welcome, maybe some good info could come out of it.
My challenge would be to ask people here to keep it civil and that if you don't like B&W there is no point in you being here. If you want to talk about other comporables, start another thread.
For the record, I am a B&W dealer , and most know this, and as such , if I can find out any important info on the brand or certain models, I will be happy to. Don't , however, post or pm me regarding sales, I don't use threads as advertising for my business, and I won't sell you anything .
So what do you own and how is it set-up?
TheEdge64
New Member
Big Grin B&W Rule !
Hello Guys & Jake
post #2874 of 13900
Originally Posted by TheEdge64 View Post
TheEdge64
New Member
Big Grin B&W Rule !
Hello Guys & Jake
You are definitely on the right track! I am sold on B&W and have three seperate systems: 801's, 804's and 603's in different applications. If you have not done so already, you might check out The Sound Factor here in LA (in Encino and Pasadena) where you can listen to the different models.
Hopefully, you can move out of your apartment soon, outherwise you may have neighbors pounding on the walls!
post #2875 of 13900
Hi
I'll be getting my first pair of speakers - the B&W 685s in a couple of weeks and I can't wait! I chose the 685s since I'll be mainly using them for music and I need them for a very small room. Right now I'm trying to decide which receiver to get. I want a stereo receiver since I don't plan on expanding to a 5.1 anytime soon. The dealer was offering a really good deal with the Denon DRA-297 but I wanted to research other receivers before making the purchase. The Denon was the only receiver I could audition them with and I was wondering, what would you guys recommend? I'm trying to decide between the Denon 297, HK 3390 and the Marantz SR4021.
post #2876 of 13900
Need some advice. I own a pair of N802's. I have never really thought they were that great especially when I compared them to my old Matrix 802's.
I am finally upgrading my processor and switching over to balanced interconnects. As I do this I am starting to question my AMP. I have a sunfire signature 5x405 amp.
Does this amp have what it takes to power a pair of N802's? Should I consider using 4 of the 5 channels to bi-amp the speakers - would that help?
Or should I use that amp for my surrounds and purchase something else to drive my N802s?
I don't want to break the bank on amps - is there is a good two channel amp or two mono blocks that will "show" me what the N802's can really do?
I look forward to hearing what everyone here has to say.....
PS - I have already put the N802's on some sound anchor stands - and I think that has helped a bit.
post #2877 of 13900
Hi !
My setup is:
front - DM602 S3
center - LCR60
surround - DM601 S3
sub - ASW 600
These are my first 5.1 speakers and because of that I'm not sure if I configured correctly all that staff. They will be used mainly for the home cinema purposes.
Here are my settings: front speakers are set to large, center and surround - small.
Crossover frequency is set to 80hz (my amp allows 80-120hz for all channels).
SW mode set to norm (+main also available)
LFE - 0db, cinema eq - off.
And now sub - my biggest concern is a low-pass filter frequency control (40-180), and defeat switch (in/out). Manual says to set it to "out" for home theatre, and then frequency control is irrelevant.
For 2-channel audio they suggest to set defeat switch to "in" position, and low-pass to -6db frequency of the satellite speakers.
Frequency range of my speakers at -6db is:
40hz and 42kHz for 602's
48hz and 42kHz for 601's
50hz and 30kHz for lcr60
So if I understand it correctly I should set low-pass filter to 50hz ?
Feel free to comment my current settings, maybe there is something I did wrong... thanks in advance for any reply.
post #2878 of 13900
I need to sell my HTM3S. Any interest?
post #2879 of 13900
What have you done to treat your room acoustics? If the answer is "minimal" or "nothing" then you should consider that as the next step.
post #2880 of 13900
Ditto. The room will have far great influence on sound quality than any change of amp will. Save your money for a while if you have to, but amps come after rooms in the priority of things. I just went down the same road with my system. Trying different amps and cables and whatnot, but I ditched that after not realizing much gain in SQ and put all of the amp money into the room, and then some. The payoff was a signifcant increase in clarity and neutrality.
http://www.avsforum.com/avs-vb/showthread.php?t=1047573
  Back to Forum: Speakers
