I really need to decide if I will stick with my 802Ds or switch to another company such as JMLabs. Any recommendations or help on this issue would definitely be appreciated. I have put items in bold that have changed between consecutive systems, and I have put words in bold that indicate I am considering two choices within the same system number. I am considering the following setups:
803D in the rear,
HTM1D or HTM2D in center,
Revel Ultima Sub 30s (setup in stereo),
Revel Performa B15a subs (setup in stereo)
Revel Performa B15a subs (setup in stereo) I haven't gotten the B15a subs yet so I'm not sure I will add them, it depends on whether the two Sub 30s in the front generate enough sound pressure to pull off the authenticity needed for total immersion in the films and/or music in a room with the general volume created by the following measurements: 18' x 33' x 9'. Some areas of the room won't have 9', in those areas, which are mostly a 4' soffit around the entire room perimeter which is 7'6" off the floor and another area that is around 4' x 12' which is 8'2" off the floor. The acoustical engineer who designed the room renovations typed this on the blueprint: "This room would benefit from 4 smaller subs. 2 subs are minimally required for this room." So I am not sure at this time if I will need two more or not. I do think that it would be great for surround music in particular as I will have them set up in-between the preprocessor/preamp and the amps acting as crossovers for the signal before it is fed to the amplifiers and equalizing the low frequency part of the signal at 80Hz and below.
The B15a has the same three parametric equalizers as the Sub 30 and I can tell you from my experiences with the Sub 30s that they work so well that I am literally blown away by the sound. First you set the gain on the subs to make sure the level at listening position is equal between your speakers and the subwoofer/subwoofers. Then you set the polarity so that the soundwaves between the subs and the speakers are aligned, this makes the speakers and subs inseparable when you hear them. Last, you do a frequency response chart using the disc supplied by Revel (for the previous steps you also used the disc supplied by Revel) and a program you download from Revel's website. The program allows you to punch in the frequency responses one at a time and when you are done you push a button and the program analyzes the entire Frequency Response. The program then gives you settings for your subwoofer's (or in my case subwoofers') parametric EQ knobs.
After you manually set all of the knobs as precisely as possible you can do another Frequency Response chart, with their program and disc if you like and don't mind how time consuming it is compared to a program like ETF. I own ETF so I just do a before and after with that to see how different the signal is after using the Revel set up program and disc. The program supplied by Revel works as advertised. My Frequency Response below 100Hz is excellent, almost perfectly flat. The bass hump below 80Hz that the 802D is critisized for on these fora and others is eradicated completely as well as some other room mode created issues. Besides lowering the gain in places where the sound signal is reinforced it can also raise the gain in areas where there are large nulls (+9 dB at most) if that is necessary.
I was surprised what a tremendous difference being able to alter the signal at 3 different points along the frequency range between 20 and 80Hz could make and have been considering a more thorough parametric EQ component that can handle ranges beyond 80 Hz. I'm not sure it will be necessary though as the biggest problems were below 80Hz in my system besides one troublesome reinforcement at around 300 Hz, which isn't terrible but could definitely benefit from some flattening out.
If anyone here is in the market for a sub, definitely consider the Revel Performa B15a as the Sub 30 is discontinued due to the new product line, the Ultima2, being released. They were very pricey too, while the B15a isn't so bad in comparison and considering all the good technology you get. My acoustical engineer recommended the B15a and Sub30 over any other subs on the market at that time including the Velodyne DD-18 which he and some other people told me are not very musical at all, the lowest frequency ranges lose speed compared to the B15a I guess. I'm not really sure what reasons my acoustical engineer had for saying the Velodyne isn't as musical, but he was right about the Sub 30s they are extremely musical. I have tried everyting possible, the Revel setup program and the parametric EQs as well as the phase settings, make the sub completely integrate with my 802Ds.
The B&W aren't worth the price IMO (the ones in the 700 and 800 series), and the frequency ranges that subs produce are frequency ranges where you won't notice any issues when using a sub from one company and speakers from another company. This makes shopping for subs a nice prospect because you are not limited by the issues you have to deal with when looking for a center channel and surround speakers, in terms of matching sound quality, timbre, tone, etc. So if anynoe is looking at subs, IMO, the Revel Performa B15a is the way to go right now. I'm not sure about the JL Audio subs that are getting a bit of notice right now on the boards, but I'm definitely going to ask my acoustical engineer what he knows about them compared to the B15a in terms of musicality and in terms of equalization (the Fathoms have some built in features that equalize the signal). I know that the JL Audio driver is only 13" compared to the Ultima 30's 15" driver and the B15a's 15" driver.
Perhaps if they turn out to be extremely musical I will put two of those in the back of the room, instead of two more Revels. Actually I will probably stick with the Revels... I don't like that the JL Audio site doesn't put in some FR figures. I know those kinds of things can be msleading and can be fabricated, but that doens't mean they can't put those figures up in a way that is honest and not misleading. I think that not posting anything is a cop-out, and I won't end up buying them because I have no reference for them compared to the Revels which list as going down to 20 Hz, with -3 dB at 18 Hz (I assume this means that they are flat down to 20 Hz then start to slope off towards 0 dB from there, starting with a -3 dB loss at 18 Hz). The actual website has these written on the page for the B15a and the Sub 30:
Enough rambling. Again, if anyone has any input, please help me!!! Just kidding on the desperation implied by the exclamation point. I really would appreciate any input, advice and other remarks. Thanks.
System 1:
800D in the front left and right,
802D in the rear,
HTM1D in center,
802D in the front left and right,System 2:
803D in the rear,
803S in the rear,System 3:
804S in the rear,System 4:
805S in the rear,System 5:
802D in the front,
Those figures help me to understand what level of low frequency sound I will be able to output in my home theatre when using those subs. At least I think they do, as I am no expert on these things. I know that companies do use figures on subs to decieve people, I don't think Revel does this kind of thing as they are a reputable company. I understand JL Audio's negative attitude towards companies using these figures to manipulate the consumer, but I need something, anything that I can use to compare their subs to the B15a, otherwise I am at loss on which may fill my needs the best. In any case though, it still doesn't tell me whether or not the sub is musical enough compared to the Sub 30 and B15a, it will only tell me how low it will go in the FR before it loses dB. Perhaps Kal has some input on the JL Audio subs as he was testing one up until recently.In-room Frequency Response: 20 Hz to f c ±0.5 dB, - 3 dB @ 18 Hz
Low Frequency Extension: -3 dB @ 18 Hz (up to full-rated power)
Please tell us what B&W speakers do you own? It would be a nice way to introduce yourself to the rest of us participating in the thread.
I don't want to see this thread shut down because of you two.
Neither one of you own B&W speakers, right? Can't a moderator remove their posts from this thread before it becomes a problem that locks the thread?
