Originally Posted by HarrisonS
Actually I am a little surprised that you are hearing distortion. You must be playing the 804's awfully loud, or else have them in a very large room, or both. I am driving a pair of 804's with a 120 wpc receiver, and have not noticed any such problems. But I have them in a small room, and have not used them at very high volumes. I also have a pair of N801's im a much larger room, but I am driving them with a 300 wpc Krell amplifier with biamping. The 801's did fine, however, with a 120 wpc Nikko amp, which I used for a short time. I don't think, however, that I cranked it up very high at that time.
When you hear distortion, does it go away when you reduce the volume? If not, it is probably in the recording. You might also consider getting a good subwoofer, especially if you will be using the 804's with movies. Also, with a subwoofer, you may not need as much power on the 804's.
thanx for the help guys.. i'm thinking it may be the recordings... i am listening at -30DB's max and it doesn't seem to go away when i lower the volume.
Regarding ICEpower, yes they're very efficient. My dealer powered the 802 with the 1077 amp. Do not underestimate the power of those little bugger.
