Originally Posted by warpdrive
Nice purchase!
Now that I see where your going with this.....If it was me, I prefer to add the Rotel. I've never heard a Rotel/B&W matching sound anything but excellent, and it would still allow the B&W's to be very well driven. You are right in that fact that the MF acts as a second power source and the overall sound quality is much more dependent on the Denon, which would be the limiting factor in the sound quality. As for alternatives, not sure if you can get Brystons in Hong Kong, but I've always loved the Bryston 4B (not sure if the pricing would be that much more than what the Rotel is going for nowadays)
Nice purchase!
Thanks warpdrive for the helpful advice! I'll take a look around to see if any Hong Kong dealers carry Bryston, though I think probably as HK is a big hi-fi market. I've seen the 4B SST online for about USD$3,000 so it is not too much more than the Rotel. I also see that it is 300wpc compared to the Rotel's 500wpc. I assume 300 wpc will be enough to drive the 802D's?
On that note, another option I'm considering is the Rotel RMB-1095 which is a 5 channel amp that delivers 200 wpc, and costs slightly less than the RB-1092. The reason I'm considering this is because this option will give me balanced power to all 5 channels and lets me avoid using the Denon as an amp at all. The drawback to this is that I will only be feeding my 802D's 200 wpc instead of 500.
What do you think would be a better option? Getting the RB-1092 to drive my 802D's at 500 wpc and letting the Denon drive the other speakers at 140 wpc (and possibly either bi-amping/bridging the HTM2D center when I buy it down the line or possibly adding another RB-1091 to drive it) or getting the RMB-1095 and use Rotel power exclusively, but only at 200 wpc?
If you think the RB-1092 500 wpc stereo amp is the better choice, do you think bi-amp/bridging the Denon to provide 280 wpc to the HTM2D would be fine, or should I shell out for the RB-1091 to power it?
I guess this question would be relevant to the Bryston as well. On that note, I wasn't able to find a monoblock equivalent to the 4B should I need it to power the HTM2D center speaker. Do you know if they make a monoblock that matches the 4B?
Thanks a lot for your advice, it's really helpful.
