@hdtimeshifter-
I think that you will be fine, they may sound a little boomy in the bookshelf. That said you will have a sub hooked up if you set the crossover at 80hz that my help. The only thing I would do is make sure that the front of the speakers stick out from the shelf. Have you heard the asw608? I like it the best for music, very tight bass in a small package.
@others-
The 684 are not that much of an upgrade over the 685. A larger sound stage maybe, but not that much more bass. If you really want floor standing speakers I would go up to the 683 or the CM9 if you can afford it. Personally I would just get the 685 and a nice musical sub. Spend the extra cheese on a center or rears.
@others-
) as your ears getting "used" to the sound.
), so I suspect 2/4 bookshelves and one center would usually produce the best result.
