Originally Posted by Vidmaven
So I have a couple of questions; earlier this week I had a pipe burst in the basement ceiling right over the family room entertainment system. My B&W Matrix HTM Center was under the deluge. It got pretty wet but was angled so it seemed as if most of the water ran off.
1) What are the chances nothing happened to it?
2) If something did do you think it's repairable?
3) If not repairable what is comparable in their current lineup? It was part of a 3 channel setup with DM604S1 so I would like to get something that would closely match the L&R.
So there are two issues to address:
1) water on electronics. Generally, if they were 'off' (not driven) nothing electronic is really damaged. If you unplug them, maybe unplug and remove the drivers to expose everything to air to dry out for a few days (upstair where humidity may be more neutral ) then put it back together, you should be fine.
2) water on wood/paper/furniture. This is the potentially trickier part. First off, I assume you wiped it all down with towels. Again, do NOT use a dehumidifier.. that could dry out the wood and parts too quick and cause cracking and warping. You want to open up the cabinet as much as possible and let it breath and slowly dry to a consistent humidity level.
If the water just ran off the edges, you are probably fine. Without knowing the extent of the exposure to water, I'd recommend better be on the safe side and allow the speaker(s) to dry out for a few days in a normal, warm room having pulled whatever drivers you can pull to open up larger openings into the cabinet as well as the backsides of the drivers. Just in case.
