Originally Posted by
hmcewin
According to Krasmusik, a regular contributor here, this ref. review used the wrong color standard charts for drawing their conclusions. The Mits is not off nearly as much their review indicates. I know my Mits is outstanding in pq right out of the box.
By the way, for the brave of heart, I checked with my Mitsubishi contact, and the review is right about one thing; the color space is not adjustable at all, service menu or not. Only the adjustments we have access too in the main menus are available even to dealers and technicians. Further, if it really bothers you (the greens look fine on mine so far w/ 40 hours on the lamp, withholding judgment and calibration for another month) -there is something you can do. If you can live with a little less brightness, the HC1100 (only sold overseas) has the same guts but with a more accurate color wheel without the white segment. It is Mitsubishi part# 499D102040, in stock and available from Mitshbishi dealers for probably around $275. Changing it will void your warranty however, and for replacement instructions and adjustments, you will need to get the HD1000/HC1100 service manual (I'm told it's the same for both models.) No, I don't have the service manual myself, sorry.
