Originally Posted by
Grand Dizzy
My room is 3.5m (11ft) square. I move house quite regularly, but that’s about the typical size of my computer/movie room.
I believe your sub should be fine for your room.
I have similar specs with my Hsu, VTF-1 in a slightly larger room.
Grand Dizzy
Yes, I do that.
That sounds like my movie collection (with the exception of horror).
Not entirely sure how much of a “bass-junky” I am.
I do have my amp set to output LFE from both the sub and front speakers, because music sounds meatier that way.
But I wouldn’t want the sub to be any louder than it’s supposed to be. I let my amp automatically set the volume of the sub, which seems well-balanced with the other speakers. I’ve read several times on forums that if you can hear the subwoofer blaring then it’s set too loud; that a subwoofer is supposed to blend in with the other speakers and not stand out.
I generally have my amp set between around -35db and -25db, turning it up as far as -15db on rare occasions. Although this is just what my amp says, and obviously isn’t real volume. I would say I keep the volume fairly moderate. I certainly wouldn’t want the neighbours to be able to hear it through the wall.
I think you touched on a couple points.
You seem to have your system set up with a lower sub level to enjoy music they way it should be reproduced. The same can be said about movies. I believe the way a system should be calibrated actually has lower sub levels than most people prefer.
The other is having a bass/LFE mix in your front speakers. It shouldn't effect music as much, as there is no LFE in music, but when it comes to setting up your system for movies the recommend way is setting the speakers to "small" (even if you have tower speakers capable of lower frequencies) to get the proper mix the way the movie theaters and Dolby intended it to be heard.
This *may be* the reasons you don't notice the sub as much. IMO, this set up may be washing out what you should be hearing through the subwoofer.
I've tried this setup before because I prefer to have my sub in a "near field" position closer to my seating position rather than next to the front speakers. One downside to this is the sub becomes localized. Having the front speakers set to have a bass/LFE mix did fix that, but the mix of the movie soundtrack sounded a bit off to my ears so switched back.
Of course, preference plays a factor, but I say give it a shot (speakers set to small) next time you watch a move with some LFE in it. You may find that you "woke up" your subwoofer.
Grand Dizzy
Good heavens!
When I’m watching a film at my very loudest, the volume is probably about the same as a quiet movie theatre (in terms of listener perception). I find loud movie theatres borderline painful, and wouldn’t want to recreate that in my home.
Besides, I’ve never had the luxury of living far away enough from other people to be able to have speakers blaring. Even when I’ve lived in detached houses, the neighbours are only a few metres away.
I live in the UK though. I think houses might be more spaced apart in the US perhaps? What sort of places do you all live?
Hmmm. I’m probably better not even starting down that route then.
I think you'll find we are all very similar. Not everyone here (well, excluding everyone in this particular thread) will try and shake their foundations with high decibels, and not everyone has the luxury as well.
I live in an older neighborhood, kind of suburbian where the average lot size is 50x100 ft. I don't have to go very far to find houses with a lot more room in between houses. Mater of fact, it's a two family house. At one time I was the very professional and for the past 17 years would never do anything to upset my income, errr, oops... I mean my tenant. Now, I'm not renting it out so I can enjoy myself a bit more. Besides this loud hobby, I have one other. Part time musician. I'm currently entertaining the idea of relocating to a better location with a single family house.
