As far as the accuracy of the CA813 goes, I'm not sure it's as accurate as people think. I've done a lot of light measurements recently for contrast purposes and it deviates from a calibrated Progressive Labs C-5 colorimeter which has also been checked against another calibrated C-5 and a LightSpex. The CA813 and C-5 are close in the bright readings but deviate up to ~23% in the low luminance range. The CA813 also deviates from itself when one tracks the lux readings vs fc.
I've spoken to both Cliff Plavin at ProgressiveLabs and Wm about the CA-813 and both have said basically the same thing. The CA813 is a good value, but it's accuracy at the bottom end isn't that great. Wm went on to say that it uses two potentiometers for calibration purposes and pot's are notoriious for drift.
. I think, for relative measurments, using the same meter, it has good value, at higher readings.
?), but any comments on the two meters above?
