AVS › AVS Forum › Audio › Receivers, Amps, and Processors › HK AVR 7300 thumps on source switch
post #1 of 51
My HK AVR 7300 has a very noticable and annoying thump when ever the audio source is switched or when ever the audio surround mode changes. The latter is the most annoying as this (the surround mode changes) happens randomly while watching OTA HD broadcasts of non HD content. I think the surround mode switching is the fault of the local TV stations feed and there is nothing I can do about it since the AVR will automatically go into Dolby Digital whenever it is available and the drop back to PLII when the digital signal is lost. I do not know why the local bradcasts have this problem but they do.
Anyway I was just wondering is this thumping normal? Is there something I can do to stop it?
Steve
post #2 of 51
Bump
Has nobdoy else experienced this behaviour with this AVR. I know this is (or was anyway) a fairly popular AVR surely someone has some thoughts on this
Steve
post #3 of 51
Originally Posted by sredmyer View Post
Bump
Steve
I have never had the problem.
post #4 of 51
it is one of those undocumented HK specials to express their love for their customers. Others include uncloseable doors, non-functional switches and vanishing sound field settings.
Enjoy your HK.
post #5 of 51
I have an AVR 635 that was hooked up to a Bryston 4b. I had the same thumping pop everytime there was a break in the digital audio stream. After a few different phone calls to HK and Bryston we determined it was the audio muting feature of the HK that was doing it. A wonderful feature that mutes the first couple seconds of music everytime you put in a CD. Brilliant. Everytime the muting feature kicks in and on, there is some type of voltage difference or spike that makes the pop noise. It's strange that you get the pop using the internal amps, but that could be the cause. It's an HK so you're bound to have many ridiculous unsolvable problems brought on by the actual design of the product.
So, now I'm back to using the internal amps of the 635 with no popping but much less in the way of dynamics, bass and punch. It is the first and last HK product for me. Good luck with yours.
post #6 of 51
I am not using the internal amps except for the center and surround channels. The front mains are powered by 2 Adcom GFA-555s running bridged.
So can I assume (since you went back to internals) that although HK identified the problem they did not offer a solution?
post #7 of 51
The only thing I can think of as a difference between my receiver and yours is firmware. Call H/K and get the latest firmware upgrade and load it. I have never had that problem, purchased mine about 1 year ago.
If you call they will help you...
post #8 of 51
Enjoy your HK.
I have never had thoughs problems ether. Is it the best receiver, no. But for around $899.00 it was a great deal.
What your rig?
post #9 of 51
Exactly. No solution offered. There is no way around the brilliantly designed muting 'feature' of the HK so you will always have the pop noises. The updated firmware does nothing to solve this problem nor does changing the polling settings on or off. The only way to avoid to popping noise is not to use an optical or coaxial input. Using the 6/8 channel direct's analog connections results in no popping noise. But that is not always the best sounding solution, depending on the source material. I couldn't take it anymore and disconnected my amp. I'm waiting now to use it for a music only setup with a dedicated pre/pro in my living room.
Also B&W700guy.....do you run your HK with an external amp?? If so, what is the amp and how is it hooked up?
post #10 of 51
Sunfire TGA5200....I have never heard a Thump, except when I turn off the amp before the receiver. I use the 12vdc for turning on and off my amp. That is the case with all of peripherals, DVD, CD., DVD-A, DT HD DVR Box, Computer or Turntable, running in all the different Surround and Stereo modes.
When did you last upgrade firmware? I have not upgraded to the last rev. The new firmware allows for viewing some of the menus in 480p/720p/1080i. Can you do this, maybe there is a problem with the new rev? If you can't, call and get the upgrade.
If you call HK they will send you a CD.
There were a few posts on this website in the past 4 months on the upgrade.
Forgot... (5) Discreet Diamond Back RCA cables connected from the Receivers Pre-Outputs to the Sunfire's Inputs. I don't plug the amps into the AC Receptacle of the Receiver; it is plugged directly into the wall socket.
post #11 of 51
STEVE..
A suggestion.
Since you are using external power amplifiers the Adcoms are using a different grounding system.. Why not run a separate ground wire from the 7300 chassis to each of the Adcoms.
post #12 of 51
I feel your pain, my friend.
Honestly, I can't really contribute much, since I don't have your AVR, but I have wanted to start a similar thread, but I just don't know where to put it.
For the record, I have a Sony STRDA-1000ES, and I too have problems with loud POPs, but I am almost positive its NOT the AVR; its the local TV stations (well, guess it could be my TV too, but I doubt it).
Whenever my local HD station goes from network to local programming and back, sometimes there is a loud POP in my speakers. Also, I can tell they switched programming sources because my AVR will also switch surround modes (say from Dolby 5.1 to ProLogic).
Now you could say its my AVR, BUT...I have my TV hooked up to my AVR via the coaxial input. For the longest time I didn't have a HDTV, and had my DVD player hooked up to my AVRs coax input, and when the DVD player switched modes (say from a title screen to start of a movie) the mode change is as quiet as a churchmouse. I heard nothing at all, just saw the display indicate the mode change. Since getting the TV, I moved my DVD player to the optical input, and again, no problems there as well.
When I asked about it in one thread in my the local HDTV reception area, there was one user that admitted he sometimes heard the same thing; other than that, the reply was mostly ignored.
There are thousands of threads that talk about getting the absolute best possible sound and picture quality, yet no search results in the HDTV section of "pops" in the audio. That is kind of curious, as it leads one to believe that they are the only one suffering from this issue, but seeing your post, along with my experience, and the one other posters reply in that one thread leads me to believe the problem is with the source material (our local TV stations), and not our equipment.
Its frustrating, but what can you do?
-Alan
post #13 of 51
Running an AVR435 with 3 pro-amps (2xBehringer 1500 & 1xCrest vs-650)
Never had any popping sounds...
post #14 of 51
Originally Posted by M Code View Post
STEVE..
A suggestion.
Ok I know this is probably a really stupid response because I do not know much about elect. but... since both the Adcoms are plugged into the switched outlet of the HK (through a transitorized thingy made for me by a freind) shouldn't every thing have the same ground?
post #15 of 51
FirebirdTN,
I can not speak for your issue (though it does sound very similar) I am absolutely sure mine is coming from the AVR. In addition to gettting the pops when the dolby mode changes, I get this same popping when playing mp3s from my HTPC and the player switches from one song to another. This makes what one previous poster said about the muting "feature" sound like the culprit. Since I believe this "feature" is supposed to activate whenever there is a break in the audio signal.
I do not get the popping when changing from track to track on a CD though...but this also make sense...since the audio signal is not broken going from one track to another on a cd there is just silence on the signal between tracks.
post #16 of 51
Ok I just got off the phone with HK support and have a little better understanding of this issue. The problem is not the muting feature, infact this muting feature is designed to eliminate the popping we are experiencing. The problem stems from the locking and unlocking of the digital stream. The reason we experience the problem on external amps (and not when using the internal ones) is that the muting feature is not applied to the preamp section but only to the amp output stage. I think that part makes perfect sense. Another obvious reason some may experience this issue while others do not is the type of connection used between the source (DTV, HTPC, DVD, etc.). In order to have the issue the connection must be digital as there is no locking on analog signals. This explains why I do experience the problem when switching mp3 tracks on the HTPC (digitally connected) but not when switching tracks on a CD (analog connection). This definition of the problem also explains the popping experienced when viewing/listening to OTA HD broadcast of non-HD content. What happens here is that the local station has a DD encoder which is supposed to switch off and just pass the network feed of DD when the network feed is DD and switch on to provide DD encoding when either the network feed is not DD or the local station is not using network feed (ie. local comercials). This switching on/off of the DD encoding causes the reciever to lose and regain a lock on a digital stream thus causing the popping.
So given that as an explanation can anybody help with a solution? HK has said that there is no way to resolve this in the reciever. I guess that means that it can not be done with a software upgrade.
BTW the problem is more than just annoying, In my case I believe it is responsible for blowing the amp in my sub (twice).
post #17 of 51
I'm still lost on this part..
You have the amps plugged into the switched outlets on the back of the HK? That can't be good. They should be plugged directly into a power strip or the wall, not the receiver.
post #18 of 51
STEVE..
I imagine the thingy turns on the Adcom amps by switching an external AC power strip.. My point is that each electrical component such as the Adcom amps and the 7300 should have a reliable, common, electrical ground without this certain noises such as pops, transients, background noise may be more audible..
post #19 of 51
STEVE..
Yes I understand this now. I brought this up to HK support when talking to them about the issue and they said although a good idea in general they doubted that it would have any impact on this particular problem. I plan to try it when I get home this evening though just the same. I understood most of what they were telling me but I am still a bit fuzzy on one thing. What exactly is being sent out the preamp outputs that is causing the external amps to thump? It seems to me that the external amps must be shotting a split second straight DC voltage to the speakers to cause such a thump. Is this true? If this is infact the case what must be being sent from the AVR's preamp outputs to cause the external amps to output a straight DC signal? Also shouldn't there be some type of device I can put in the preamp output connection that would filter it out before it gets to the amps?
post #20 of 51
Nice job, sredmyer. Now we might be getting somewhere. I've wondered about a filter of some sort too. I don't know if there is such a thing, but it seems like there should be some way to make this work. Is it just another HK oversight?
How do dedicated pre/pro's work? Do they pop the same way? How do they regulate their voltage issues and why can wouldn't the reciever work in the same way?
I am encouraged though. These are the first real answers I've seen from HK.
post #21 of 51
Spydah,
I am not so sure this is as much an answer as it is a non-answer since they (HK) said there was no way to disable the feature and even if there were that would not fix the problem. Thus no solution...no answer.
Is it just another HK oversight? How do dedicated pre/pro's work? Do they pop the same way? How do they regulate their voltage issues and why can wouldn't the reciever work in the same way?
The following was copied from the Anthem web site http://statement.anthemav.com/HTML/Products/D2/D2.html
All operational amplifiers (including those used in Bass Management) are audiophile-grade Burr-Brown (OPA2132) FET-input type. These op-amps significantly reduce DC offsets for greater signal precision as well as providing immunity from pops during switching.
Based on this statement it appears to me as this popping (or thumping) on source switch is not an HK issue. That being said though other preamp manufacturers have obviously figured out how to control it. While I realize the HK AVR7300 is not in the same class as the Antem D2 it is no slouch either. Furthermore many much less expensive receivers do not have this issue (or at least the issue is controlled to the point it is not noticed by the end user) so why can't HK engineer a solution that works? I think their solution to the problem (muting the output momentarily) is ingenious but unfortunately it is an incomplete solution (only protects when using internal amps). Please do not take this as a flame on HK aside from this issue I love this AVR. I have owned it for nearly a year now and have just put up with the popping cause otherwise this thing is great. I would still be just putting up with it except for the fact that this issue now seems to be the the cause of me blowing my $1k Klipsch RSW-12 sub's amp twice. Obviously with this problem this popping issue has become a deal breaker for me...if I can not find a solution soon I will be getting rid of it and getting something else ...maybe that Anthem D2 and a few more of the Adcoms
post #22 of 51
There is no oversite by H/K on this that I can see?
post #23 of 51
sounds like HK is subjecting itself to different laws of physics as apparently most other electronics manufacturers have figured out how to resolve this in their receivers.
that fact that HK isn't able to do it doesn't mean others cannot.
post #24 of 51
I do not think they were saying that it was a literal imposibility...just that there were no user settings, software configurations or firmware upgrades which would change this behaviour.
post #25 of 51
There are so many freaky little quirks with these H/K's and you don't see that they may have missed the boat on a few things? Why do people give H/K such leeway? They have a $1400 receiver that can't be hooked up to an external amp without a loud pop, it cuts off the first second of music every time it starts a CD, the software locks up, and on and on. These are ridiculous quirks to have to deal with on a unit at this price range. There are some HK owners with no problems. They are the few and the proud. Most have issues and issues that should not happen at any price range.
HK has come right out and admitted that the pop is unavoidable and that the missing music at the start of a CD or movie is also unavoidable. Unless you use the analog outputs. Did HK product developers honestly believe that a customer who would shell out $1400 wouldn't mind these flaws? I'm stuck with mine even though I got a deal. I'm not going to find some sucker to buy this so I can replace it. That's why it's so frustrating. I'm stuck with something with no fix. Unless I can find a custom repair shop to go in and upgrade and fix these quirks.
Anyway, I'm glad to have a reason behind the problems even though there is no apparent solution. Would a more modern amp have a better capability to handle what the HK does than an older amp? My Bryston is over 20 years old, with some recent upgrades. Now that I've unhooked it I really miss the sound it gave me. I'd love to figure out a way to make it work.
post #26 of 51
I have never had a problem with Popping. I don't know if you have a Ground problem like M-Code suggested or something else. Next the CD issue, never had that issue and what ever the on and on's are?
Does it match my B&W's, not very well. Its sound good in all the Surround Sound Modes, but in Stereo it is only ok. My AVR 7300 is only a Stop Gap till the new Processors come out. (IMO) In guess it's worth $1,400.00, but I would not pay that for a 7300. I don't know if you have a compatibility problem with your older gear or something else?
I'm not sure if you are working the problem and just blaming H/K?
Well, who ever said these are Unavoidable at H/K is wrong. You mention the "POP", my Rotel RMB-1075 amp never did it and my Sunfire has never made a Popping sound (only when I turned off the Amp before turning off the Receiver.) does physics change in my household compared to yours, did you try what M-Code said, or ask for clarification? A few of us are doing the same thing and never had a problem and you dismiss it. Maybe you should try this with other Receivers; you will probably have the same problem. I don't know of one Receiver that allows you to adjust the time of the Mute Function.
Could be a compatibility problem? How is that HK's fault with a 20 yr old amp?
I know there are many complaints about H/K, but the 7300 seems to be a work horse (IMO). And no, I am not kidding
Edit: I checked your profile. do you have an AVR-7300 or an AVR 635? We are speaking about the 7300. These are two different receivers. If you have the 635, it has nothing with our experiences and what we are talking about.
Edit2: Didn't see post in this thread- He has a 635-Sorry
post #27 of 51
B&W700guy,
In Spydahs original post to this thread he stated that he had the HK 635.
I believe he contributed by simply stating that he was experiencing the same or similar problem as I am with my 7300. He further mused that since both these different recievers exhibited these similar behaviours it must be a fault common to HK.
With that said, I would like to take a moment to agree with your point on this reciever...I have had it for nearly a year now and (except for this issue) I love the thing. I really love all of its features and for surround I really enjoy its sound and power. However, I think that it is not a very accurate amp (note this is an opinion only). For music I prefer 2 channel stereo listening and I want my HFs to be as bright as they were intended to be. The HK (in my opinion) tends to soften the HFs a bit. It is for this reason (and to add some headroom for tighter bass control) that I use external amps for the front mains.
I have tried all of the various multi-channel modes offered by this reciever on music and I just dont find them very appealing. To me listening to music like this is like listening in a very bad room where reflections are muddying the intended sound. To be fair here though, I should mention that I have not had the opportunity to listen to any music that was mastered in multi-channel (SCAD, DVD-A). I have quite an extensive mp3 library (over 100gigabytes ripped at 256kbps from standard CDs), which is the source for the majority of my listening.
I have heard (read) that many like the multi-channel music formats. I do not really understand this, possibly because (as stated above) I have not heard any that was recorded that way. When I listen to music I want it to sound like it would if I were listening to it live at a concert or in a club. I have not been to a great many concerts (do not enjoy the crowds) but I have been to a few and I have been to many club performances. In all of these live performances the sound stage comes from the stage which is infront of me (no surround here). For me music, unlike movies, is not attempting to envelop me or make me feel like I am part of the scene. Music is a performance happening infront of me. Movies on the other hand should make efforts (through sound as well as visual cues) to make me feel that I am part of the unfolding action/drama. So for me surround sound is for movies and 2 channel is for music. I might enjoy the inclusion of a center channel for music listening to anchor the sound stage for "2 channel stereo" music, but none of the 3 channel modes of the HK give me a satisfing experience. This is in part due to the fact that although all of my speakers are timbre matched (Mains Klipsch RF-7s, Centet Klipsch RC-7, Surrounds Klipsch RS-7s) the mains are amped by (as mentioned above) external Adcom GFA-555 amps while the center is amped by the HK 7300. The difference in the HFs between the mains and the center in this configuration is quite noticable.
post #28 of 51
B&W700guy,
Now that I have completed that long winded rant I am very interested in your setup. Based on some of your previous post to this thread I gather that (at least in the fact that you are using the 7300 for a preamp for your mains) our setups are similar. I would like to know how our setups differ since you do not experience the issue. Maybe I simply have my system configured wrong. Lord knows that with all the features and settings in the 7300 I have no idea if mine are optimal (or even correct). This HT thing has been a real learning experience for me and there are certainly some settings (most having to do with the Foruga processing) that I simply have no idea what they are for or how they should be set.
post #29 of 51
Sorry, I missed that he did have 635. But it still gets down to working the problem. This was what I had a problem with from Spydah ...
"Nice job, sredmyer. Now we might be getting somewhere. I've wondered about a filter of some sort too. I don't know if there is such a thing, but it seems like there should be some way to make this work. Is it just another HK oversight?"
the 635 is a different receiver from the 7300. And we are trying to help you with your problem.
Did you try what MCODE mention, running a ground from your receiver to the amps?
MCode knows the H/K line better then anyone. If you stay on track, I am sure he will help
post #30 of 51
I also did not think that particular apparent slam on HK was warrented. Their systems work exactly as designed and many have no problem with that design (loss of a few milliseconds of audio on source switching).
No I have not yet gotten to trying that. My system is not very friendly when it comes to changing wiring (requires alot of heavy lifting). I hope to tear in to it and try the ground thing this afternoon.
Again though, can we investigate the differences in our setups? Maybe that will lead to some resolution here.
