AVS › AVS Forum › HDTV › HDTV Technical › D* 811 infrared sensor
post #1 of 2
Can anyone tell me where on the face of the 811 the infrared sensor is located? When watching tv, the 811 is behind the screen so I want to attach an infrared relay to use my Pronto remote. Thx.
post #2 of 2
The 811 uses RF also, so simply use that instead.
  Back to Forum: HDTV Technical
