amirm confirms DTS output for the Xbox 360 HD DVD
"Just a quick FYI that we are looking at this problem. I don't have an update on it because I was on vacation for a while. But for now, wanted to let you know that we are finalizing our DTS encoder which once done, should produce the same experience as the Toshiba player which everyone was happy with...."
Time to return my HD-A1...
EDIT
Since so many people seem confused:
HD DVD DTS --> Decoded on Xbox 360 --> Player sounds mixed in --> Re-encoded to Dolby Digital 5.1 --> Output via SPDIF optical
HD DVD TrueHD --> Decoded on Xbox 360 --> Player sounds mixed in --> Re-encoded to Dolby Digital 5.1 --> Output via SPDIF optical
HD DVD Dolby Digital Plus --> Decoded on Xbox 360 --> Player sounds mixed in --> Re-encoded to Dolby Digital 5.1 --> Output via SPDIF optical
Thus, your receiver always receives Dolby Digital 5.1 (640 Kbps), regardless of what the original track was. However, some people have noted that on some tracks on some discs, the sound was a little bit flat.
Microsoft will be releasing an update that will allow:
HD DVD DTS --> Decoded on Xbox 360 --> Player sounds mixed in --> Re-encoded to DTS --> Output via SPDIF optical
HD DVD TrueHD --> Decoded on Xbox 360 --> Player sounds mixed in --> Re-encoded to DTS --> Output via SPDIF optical
HD DVD Dolby Digital Plus --> Decoded on Xbox 360 --> Player sounds mixed in --> Re-encoded to DTS --> Output via SPDIF optical
This new DTS output (1.5 Mbps) should hopefully correct the "flatness" some people have noticed with the previous Dolby Digital 5.1 output on the Xbox 360.
EDIT
