AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Remote codes for Motorola DVR DCT6412
post #1 of 4
Has anyone been able to locate a code that works for Motorola DVR (DCT6412)using the LG remote. I just got a 42LCD2 and I was able to program everything except the DVR box. Thanks.
post #2 of 4
More likely to work the other way. Have the cable remote work the Cable box and the TV. Never too sure on everything else
post #3 of 4
Try the Jerrold codes. I believe it is either 074 or 081 - just start with the high Jerrold codes listed in the manual. Just did this with the LC2D last week.
Ben
post #4 of 4
Ben,
Thanks, I'll give it a shot.
  Back to Forum: Remote Control Area
This thread is locked
