AVS › AVS Forum › Audio › Speakers › Thoughts on Streem Speakers?
post #1 of 5
Is the jury still out on Streem speakers? I'm trying to find reviews for the FS 808's. I couldn't find anything on the site about them. Any help would be appreciated.
post #2 of 5
Im also considering them and found some reviews at AudioReview.com. Looks like people have liked them alot. This is good considering that you spend under $700 for 5 speakers including two towers.
post #3 of 5
AudioReview reviews are totally unreliable. Anyone can post reviews there, including shills for a company looking to publicize themselves. Read how similar the reviews are to each other. That's suspicious right there.
post #4 of 5
I was looking into those since they seem to be cheaper than JBL or Klipsch which would break my budget. and don't go down below 50 Hz..
post #5 of 5
You get what you pay for - remember that. Streem isn't around here much because they are a 'white-van' speaker. If you have them - no offense. If you want a large speaker and want to pay as little as possible, maybe these are for you. But I warn you, you found this site, so you'll be reading a lot on here, - those Streems will be upgraded as soon as you have more money.
Personally, I'd check the used market. You can get a lot of speaker for $700 - certainly ones much better than Streem.
  Back to Forum: Speakers
