Originally Posted by djoberg
I am wondering though if there is a difference between the two series. You have the HL-R series and I have the HL-S series, and my tech said that with the new LEs there isn't any need for adjustments, but perhaps that is only true for the HL-S series. Does anyone have any thoughts about this?
My only thought is that there is that I haven't heard of an automatic focus feature, and that the mounting location will come close to the correct focus some of the time. For a lazy tech I'm sure that's close enough. He gets paid for the call so that the faster he is in, and out, the more money he will make.
Eliab has stated that a lot of sets don't need to be focused when he does a calibration, but a significant number do. If you are the one in a hundred that does need the lens to be focused then a 1% rate is significant. My memory isn't clear on this, but I think Eliab said he does a focus step about a third of the time.
You can use a test pattern from a calibration disk like DVE to see if your set is not focused correctly. Check the link to Eliab's tutorial at the bottom of my post.
