AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Mvix Wireless Hi-Definition Media Player (MX-760HD)
Mvix Wireless Hi-Definition Media Player (MX-760HD) - Page 20
post #571 of 589
Burnerbum;
Have you experienced video problems as I decribed in my previous post with your 760HD?
post #572 of 589
Originally Posted by robertpcx View Post
Burnerbum;
No i haven't. But i only use mine for DVD ISO files which it plays really good. The only problem i have is it sometimes doesn't shut down properly. I turn it off, the picture goes off but the unit doesn't shut off and i have to unplug it. This happens very infrequently, I wrote Mvix about it a couple of months ago and still waiting a response. They are the worst in service and firmware upgrades don't exist. Too bad because its really a nice unit. I'm pleased except for the occasional shutdown problem. I don't use it for music or photos so i can't comment on that part of it. I was going to buy the Lim but i've been reading the forum for the past few months and they have big problems too. I do have the PopCorn Hour on order. Due sometime in March. It really looks interesting and seems to have good support. It's really a shame these companies are allowed to sell products that don't work as advertised and get away with it.
post #573 of 589
Has anyone experienced video problems as I decribed in my previous post with your 760HD?
post #574 of 589
Burnerbum;
I've not had any problem shutting down my 760HD however it can take maybe 30 seconds before it will shut down.
At first I thought it would not shut down but I learned to just be more patient with my unit. Takes more time to shut down then I would like.
Except for the black screen problem I've been experiencing the 760HD has lived up to most of my expectations. One thing I would like to see it do, would be able to leave it plugged into a computer via USB and so then through software interface access the USB connected computer, I would not have to disconnect the USB cable to the computer all the time in order to play my media content as I do now.
thanx
robertpcx
post #575 of 589
Hi Robert,
If youe 760 & remote arrived clean & unscratched then I wouldn't bother returning it. It's really quite a good little unit - far cheaper than an HTPC and nice'n'quiet.
ISO DVD files generally play well when mastered correctly. I don't know what sort of encoding you're doing, but check the bit-rate and the MPEG-2/VOB streams you're encoding into your home DVDs - of the bitrate is too high then you may choke the 760HD (and most other players). For MPEG-2 DVD (720x480), a bitrate of around 4.0 - 5.5 is appropriate.
Another quick check is whether your home DVD's frame rate matches the 760HD's setup... if your TV/LCD supports both NTSC and PAL, then try switching the 760HD into NTSC (if currently in PAL) or PAL (if currently in NTSC) and then try playback again.
The black screen at the end of playback is a known issue
post #576 of 589
Hi Robert,
post #577 of 589
Hi Robert,
The black screen at the end of playback is a known issue with the current firmware. Generally pressing STOP, RETURN or POWER-OFF and the end of the movie will get you out of the blank screen the fastest. Like Burnerbum said - it usually takes 30 seconds or less.
Most cheap media players have their short-comings - the MVIX is no excpetion. It is, however, built on top of a really good hardware platform (the Sigma Designs chip inside is a real video power house), which means this: Hang on to your unit if you like it... because there are some of us who are looking to rewrite the firmware to take full advantage of that amazing hardware.
post #578 of 589
There is a known problem with DVI/HDMI output on the MVIX using firmware 1.1.27. Upgrade the firmware to 1.1.28 beta9. They made several improvements to digital output in that release.
Get it here.
http://www.eunicorn.co.kr//mvixfirmw...1.28-beta9.zip
You may also want to take a look at www.mvixcommunity.com. Its a very active community dedicated to MVIX products.
post #579 of 589
Hi All
it is done on the french forum by ArtZ.
http://forum.hardware.fr/hfr/VideoSo...t_99464_63.htm
after modification of header of the firmware 2.0.0 and 2.0.1 of mvix HD780 you can upgrade your mvix without problems.
but FTP and HTTP functions are not installed.
you can download modified files here
mvix-fw-2.0.0.pkg :http://rapidshare.de/files/38619768/...2.0.0.pkg.html
mvix-fw-2.0.1.pkg : http://rapidshare.de/files/38619949/...2.0.1.pkg.html
Please we need help for FTP and HTTP.
Darkang
post #580 of 589
Originally Posted by Darkang View Post
Hi All
Darkang
you mean you need an FTP server lol give me some days then i will bring you Telnet and FTP and some other stuff if you want.
cHarOn
post #581 of 589
Thanks a lot cHarOn99
Regards
post #582 of 589
ok first step is done i open up the firmware an enabled telnet and an ftpserver but my produced pkg file dont works looks like the header is different but np i will try to make it with recoveryoption maybe this works or i have to rework the header need some more time.
oh and maybe someone can check out if ext3 or ext2 hdds are inside working if someone wants to check it out
cHarOn
post #583 of 589
Hi All
Here is the Olav modified firmware 2.0 for HD760
http://mvixcommunity.com/showtopic.php?tid/711/
Enjoy
Darkang
post #584 of 589
i already see it so i think i can stop working on that mvixcommunity is doing the job faster
post #585 of 589
New official firmware for 760HD
http://www.mvixusa.com/support/index...temid=37&nav=0
Any chance of getting a modded OLAV release soon? I can't live without my FTP.
post #586 of 589
Check at www.mvixcommunity.com
post #587 of 589
maranite
thankyou for the help I switched to pal and that did the trick;
Sorry to have taken so long to respond.
I really like this unit.
robertpcx
post #588 of 589
Anyone else lose 1080p as a display option after the latest firmware?
post #589 of 589
I ended up "downgrading" my firmware back to 1.1.27 (or whatever the number is) over the weekend because my 760 was just a crap-shoot whether or not it would display the video. The audio was still functioning, but we tried watching a movie 4 times and couldn't get it to work. The first couple times we would get to the menu and when I hit Play Movie, the video would drop out. This has happened in the past, but usually restarting it would work. I went back to the .27 firmware release and the movie played without a hitch. I also had my 1080P setup option back.
