Originally Posted by esjerry
I got my BDP-S1 on Dec 6th, just couldn't wait any longer. I intend on taking it back as it has locked up on me 4 time, 3 of these time I had to unplug the unit and let it reboot, it has done this on SD-DVDs and BDs. never on the same disc. I find the image to be very soft and not near as 3D looking as my JVC D-VHS deck. In order to see detail in black I had to set a memory with the black level turned up as high as I could. The unit does a poor job in high contrast scenes such as daylight and a shadow this lproblem exist on both BD & SD-DVDs, ie Great Raid chapter 10, the shadowed parts of faces are black with little to no detail, WTC and Phantom is just as bad, I don't have this problem with either my Denon 3910 or Oppo 981. I was also disapointed with the deinterlacing of SD-DVDs. Recognizing Bd to be in its infancy I am still disapointed, I will say the BDP has less video noise than my D-VHS and is very smooth on 24fps mode during film based material, that is about all it excells in. I put my name on the waiting list for a Pioneer. I have a Panasonic AE900 720p 3LCD projector and took the unit to a friends house and hooked it directly to his Sony VW50 and had the same image complaints.
I have had the same freezing problems. However, I have had no problems with black levels and I don't recall anyone else having mentioned problems. Have you checked the color space settings? If you have DVI in the chain, as I do, it has to be set to 16-235 to avoid black level problems.
